Question about Toro Garden
I think I need to add hydraulic fluid but am not sure of what to put in and what level Wheel Horse 257-H. The sticker says to use SAE 20. Do es that mean regular 20 weight oil? Also, I see no indicator for the level of the oil so I am not sure how much to add.
5 Suggested Answers
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
braintrust
  • 62 Answers
SOURCE: Snapper Yard cruiser zero turn hydro pumps
should be on dip stick other wise use 90 wght wont hurt anything
Posted on Oct 27, 2009
riceski
  • 1851 Answers
SOURCE: 2007 craftsman dys 4500 model
Call your local sears company parts house they will fix you up.
Best of it
Posted on Nov 03, 2010
ToolBoxHero
  • 171 Answers
SOURCE: I have a 8 hp
Your question as I received it did not specify the engine make, but most 8 hp Techumseh, B&S and Powermore engines take 22 to 32 oz of oil. Buy a quart, put two-thirds of the quart in the engine and check the level with the dipstick or fill hole. Add more if needed to come up to the "full" mark.
All the manufactures and Craftsman recommends 5W30 for 4 cycle winter use.
You can use regular sae oil, but I prefer to use Mobil ONE or a heavy duty oil because air cooled engines run hotter than car engines. Look for a SC/SD or greater rating on the bottle.
Change your oil once a year.
Feel free to as any other questions about your snow blower. Don't forget to rate this answer!
Posted on Jan 12, 2011
I have a 2001 Chevy Silverado that slips going from 2nd to 3rd. When you first crank it up it has to warm up before going into reverse. Its a 2 wheel drive. What could it be
Check and make sure that there is enough fluid in the transmission by checking it when it is warmed up, on level ground with the engine running and the gear selector in park or neutral. If the fluid level is too low then add fluid until the level is within the "SAFE" range on the dipstick. If there isn't enough fluid that could cause the symptoms you described. Also, and more importantly, make sure that there isn't too much fluid in the transmission because the fluid can get bubbles in it by the rotating parts in the transmission which will cause hydraulic circuits weaken and basically will quickly wear out the friction materials in the transmission and it will need to be rebuilt. So if there is too much fluid, then I recommend draining the fluid and changing the filter then making sure it has the correct amount.
May 06, 2014 | Cars & Trucks
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
How do i check fluid for convertable top
"How do I get the air out of my hydraulic system"?
  • Remove the reservoir plug on the motor pump. Leave the plug out and do not put back until you have finished.
  • Fill the reservoir 3/4 full with fluid (to the bottom of filler plug hole). Put a rag under the hole to catch overflow that will occur as system fills.
  • Run the pump for 15-20 seconds. Stop. Check your fluid level and refill to bottom of filler hole. Continue running the motor in the same direction for an additional 15-20 seconds. When the top gets to the end of cycle, check your fluid level, fill to bottom of filler hole, and run the motor in the opposite direction.
  • You are literally running the top all the way up and down sereral times. Checking the fluid level as you go and fill as required, leaving reservoir 25% empty.
  • When you are no longer able to add fluid, put the top in the down position. Check the fluid level one last time, should be to bottom of filler hole. Put the plug into reservoir.
  • Apr 01, 2012 | 2004 Ford Mustang
    How to drain and put new transmission oil on my chevrolet aveo 2005 manual transmission?
    you dont ---end of story it should never need changing on a modern vehicle ,unless you take the drive shafts out to do a clutch then you top it up through a filler plug at halfway level on the gearbox ,Dont make work .
    Aug 17, 2010 | 2005 Chevrolet Aveo
    How to bleed brakes on 2002 toyota sienna
    Here is the procedure from the service manual. I would add just one thing. Do each wheel in this order
    1. right rear wheel
    2. left rear wheel
    3. right front wheel
    4. left front wheel
    BLEEDING
    HINT: If any work is done on the brake system or if air in the brake lines is suspected, bleed the air from the system.
    NOTICE: Do not let brake fluid remain on a painted surface. Wash it off immediately.
    a)FILL BRAKE RESERVOIR WITH BRAKE FLUID Fluid:SAE J1703 or FMVSS No. 116 DOT3
    b)BLEED MASTER CYLINDER HINT: If the master cylinder has been disassembled or if the reservoir becomes empty, bleed the air from the master cylinder.
    c)Disconnect the brake lines from the master cylinder. SST 09023-00100 Slowly depress the brake pedal and hold it.
    Block off the outlet plug with your finger and release the brake pedal.
    Repeat (b) and (c) 3 or 4 times.
    BLEED BRAKE LINE
    1. Connect the vinyl tube to the caliper or wheel cylinder bleeder plug.
    2. Depress the brake pedal several times, then loosen the bleeder plug with the pedal held down.
    3. At the point when fluid stops coming out, tighten the bleeder plug, then release the brake pedal. Torque: (Bleeder plug) Front brake caliper
    : 8.3 Nm (85 kgf-cm, 74 inch lbs.) Rear wheel cylinder: 8.5 Nm (87 kgf-cm, 75 inch lbs.)
    4. Repeat (b) and (c) until all the air in the fluid has been bled out.
    5. Repeat the above procedure to bleed the air out of the brake line for each wheel.
    CHECK FLUID LEVEL IN RESERVOIR Check the fluid level and add fluid if necessary. Fluid: SAE J1703 or FMVSS No. 116 DOT3
    Jun 25, 2010 | 2002 Toyota Sienna
    My radiator was replaced and now my power steering won't work. Could my lines be crossed. It is a 1992 Lexus ES 300
    Does you vehicle have a hydraulic cooling fan on the radiator? The hydraulic fan system is ran by the power steering. The fluid level for the power steering is full?
    Jun 03, 2010 | 1992 Lexus Es 300
    When I back out of the drive way, Iturn the
    This may be from the power steering. Check for leaking fluids underneath. You may also inspect the steering boot for oil inside. It may be bad seals, broken parts or incorrect fluid or fluid may be at the incorrect level.
    Oct 27, 2009 | 1996 Lexus ES 300
    How do i check or add transmission fluid
    first make sure the car is up to operating temp. with car running and on level surface, pull out the stick on driver side of engine that says transmission fluid. wipe it off and reinsert the stick. the bottm of the stick has markings on it to tell you if the fluid level is ok or low. tranny fluid is added thru the tube for the stick. you will need a funnel to add fluid.
    Oct 08, 2009 | 1995 Lexus ES 300
    Am replacing power steering pump. Need to know procedure for bleeding fluid from lines and diagram for serpentine belt configuration.
    The system will bleed out the air by turning the wheel all the way from one side to the other repeatedly, do this action at least 10 times to be sure all the air is remove from the hydraulic system. Be sure not to allow the fluid level to drop too low or air will get back into the system.
    Oct 02, 2009 | 1999 Pontiac Bonneville
    What kind of oil do I use in a Wheel Horse lawn tractor?
    Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
    DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
    Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
    Jun 24, 2009 | Garden
    Garden Logo
    Top Toro Garden Experts
    Joseph Mueller
    Joseph Mueller
    Mike Squire
    Roland W VanLue
    Roland W VanLue
    Are you a Toro Garden Expert? Answer questions, earn points and help others
