Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I have segate free agent desktop 250GB, that left working. it's not recognized anymore by the operating system. The os reads the drive and the usb icon is diplayed on taskbar, but the volume is not displayed on explorer, no unit letter for the hard drive device is assigned. I checked in device manager and in pc management and there's the drive but i cant access it. Hope understand Regards
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on May 20, 2011
I have 250GB segate internal hard disk but framework is corrupt how i upgrade or recover my date (Disk not detected)
if its not detected this solution maybe crazy but sometimes it will work.. cover the hdd with polythene (air tight) and keep the hdd inside the refrigerator - freezer for 4 - 6 hours and try to connect as secondary hdd (not master) in linux os installed computer and try to recover the files.
Aug 16, 2013 | Seagate Barracuda 7200.12 250GB Hard Drive...
Is it possible to partion System drive.?
If your C drive take up all the 250GB, and the used data is not up to 250 GB( I means there are some free space on your c drive) you could use other partition software to release some free space ( resize partition) then create new partition, with the help of partition software, it could apply the operation without re install OS.
Oct 23, 2012 | Microsoft Windows XP Professional SP3 Full...
It won't connect
re install your os xp sp3 then connect ur mobile drive
Aug 01, 2012 | Freecom Mobile Drive XXS 250GB, USB 2.0...
How can I fix my Seagate Free agents 250GB? It gives a faint beep and not recognised by the system
try to hard boot your hard drive by removing the cables and press n hold the system since your hard drive is inserted there. But if it is a separate device from the pc, do the same separately. If ain't work then go ahead & contact Seagate for repair..
Sep 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Verbatim portable hard drive model #JH8916 that has a capacity of 250GB that seems to be malfunctioning and isn't recognized when the USB cable is plugged into my computer, an HP tower. I...
This is a common problem with external drives, I have had it happen to Segate, WD, and a few off brand drives. Usually when one of these drives gets flaky, you have 2 options:
1. do a google search on your particular model on how to remove the drive from the case, then install in a desktop computer
2. use disk recovery software to attempt retrieval of files
The first on will work if there is a problem with the driver interface to usb board that is built into your device. By installing in a desktop, you are bypassing this potentially bad part. This step will also make the 2nd option run faster if you have to resort to it.
A good rule of thumb on these devices is to never have only 1 copy of the data.
Good luck retrieving your data!
John Vickers
Aug 12, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I have the western digital media player and it won't read my hard drive
Segate free agent External hard drive not recognizing as a drive
Although in device manager mass storage device is taken as drive for that.
one pop-up is coming "your usb could perform better in usb 2.0
operating system server 2003.
the same hard drive is working fine with windows XP system,but not working with server.
Jan 12, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
I have seagate free agent 500gb when i plugged it 1st time everything was fine, now windows vista is telling me that cannot recognize it
Power cycle the drive itself; once the interface is reset or the power restored to the external drive, Vista will be happy with it again (I rather expect.) Don't forget to put vibration isolation mounts under your drives if summer construction/excavation is coming.
May 08, 2008 | Computers & Internet
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
79 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
