Question about Hayward 250kbtu Ng Pool Heater - Inground
We have a 2 yr old Hayward H350FDN pool heater that has given us problems from the beginning. This year the error codes have been bd and then switches over to CE, I have checked the continuity and everything checks out. Where do I go from here and what needs to be checked or replaced?
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
  • 760 Answers
SOURCE: Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Posted on Jul 18, 2010
StepehnD
  • 78 Answers
SOURCE: I'm receiving an error code CE on my Hayward H
Open up the control panel access door on the front. (the display). Remove the 2 screws at the top and tilt the assembly out. There should be a tab on the bottom that helps keep the assembly stable. Check all the connections on both boards for fit and broken wires. If all is ok, I would shut the supply power off, then back on and see if the data transfer works. If not, bad boards.
Posted on Jul 25, 2010
Testimonial: "Great advice. Working like a charm. No loose wiring. 2 large beetles between the circuit board and the display. Blew them out and it works great."
  • 368 Answers
SOURCE: The code CE is showing
The CE code indicates a "Communication Error". This indicates there is a communication issue between integrated control board (ICB) and the display board (DB). The DB is the one mounted on the backside of the keypad.The ICB is the one back in the heater behind the display board. The two boards are joined by a ribbon cable that passes communication between the two. I suggest you contact the Hayward technical support number and they may be able to help you with the next step. I hope this helps.
Posted on Aug 08, 2011
Hayward pool heater will not ignite
if blower runs check ignitor if not check safety circuit
Apr 04, 2014 | Hayward H350fdn Low Nox Nat Gas Swimming...
Bd error code on hayward 400 pool heater
heater shows power, I had to replace three mother board according to tec. Still no sign of egniting. All it does is shows code of bd? what is that? do i need to reset something. help prices are killing me.
Feb 10, 2013 | Hayward H-series Electronic Gas Pool...
How to fix bd error code on Hayward pool heater h series
Problem could be ordinary cleaning and maintenance, or bad control board.
Copy following link for Hayward error codes:
There are several entries for error bD
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Hayward manuals on following links:
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
http://www.hayward-pool.com/pdf/manuals/H-series-Hxxx.pdf
Oct 13, 2012 | Pool & Spa
My hayward pool heater gives me a code sb what part is this
Possibly failed keypad, or stuck key on keypad.
This product should be under full warranty, and installer should be called.
Hayward 350 product manual: Error codes start page 38 do not show Sb
http://www.hayward-pool.com/pdf/manuals/Manual285.pdf
However Sb error code shows on following manual as 'Keypad failure' or 'stuck key'... one of the keys is stuck longer than 30 seconds, but control will still function, replace keypad.
Sep 20, 2012 | Hayward H350FDP Low NOx Propane Gas Pool...
IMy heater does not turn on, I getting a "F1" code.
I looked up the manual for this heater and it doesn't document the "F1" code. For this reason I would call Haywardtechnical support at 908-355-7995 and they should be able to help you resolve this issue.
Please let me know how this works out. Thank you.
Sep 02, 2011 | Hayward H350fdn Low Nox Nat Gas Swimming...
Have a h400ng with a bd code on the board
Thank you for posting your question here on Fixya.com.
BD or BO? I am not aware of a BD error but BO means the heater is set to bypass operation which means it is set up to run with a remote. If you have a remote in the system it is failing; if not you need to reset the dip switch (#2) to the off position. For help with these steps please refer to the owner's manual here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Jan 05, 2011 | Hayward H Series Pool & Spa Heater 400k...
My H350FDN heater is just over a year old and has been used very little - maybe 6 times. Now I am getting the AO error code which seems to mean a vacuum switch or relay problem. Any ideas on where to start...
On your fan housing you have a hose coming off it this runs to a pressure switch that works on vacume. This hose the connection on the housing the pressure switch or the wires going to the pre. sw. could be the problem. I would start with these. If the problem remains or the fan won't it may be time for a repairman. Good luck.
May 08, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward 250kbtu Ng Pool Heater - Inground Logo
62 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
