Question about Compaq Presario CQ61-310US Laptop
When plugged in there is cross showing on the battery indicator and it shows also considering battery to replace it.The life of the battery is to fast instead of 4 hrs but less than 1 hr.
  • 661 Answers
You need to replace the battery, most likely. it sounds like your battery has lost the ability to hold a charge
Posted on May 20, 2011
    Guru:
  • 811 Answers
It seems that you battery is not taking a good charge any more that is an indication that you may want to invest in a new battery for your lap top I usually get mine they are way cheaper than the factory ones. Make sure that you get the right match exactally for it. If this does not do the trick then purchase a new power supply unit also start with the battery first they are cheaper both are not that expensive if you go online I use amazon.com and then type in the model of your computer. Thanks for using fixYa! John
Why the battery shows cross signal? and why don't the battery not give enough backup?
ur battery is dead, i consider gettin a new one, cause a dead battery can lead to other issues.
Jul 28, 2012 | Dell Inspiron 1545 Notebook
Bettery problem
Replace the battery, it is bad...
Jul 09, 2012 | Dell Vostro 1088
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
My laptop shows red cross sign in battery and says consider replacing a battery!!what to do does it have any solution and battery life has decreased to 50 min. from 2 and half hour,i bought it just a year...
If the message says consider replacing the battery, I guess the battery life is about to end.
Its good to replace the battery if you have used to laptop for more that 3 years now. Normally that is the max battery life.
However, if the laptop is new and still under warranty, you need to contact your vendor for possible free replacement, since it is abnormal for the battery to wear in such a short time.
Also make sure the replacement battery is perfectly compatible to your laptop. Your vendor can guide you more.
I have replaced batteries in the past. Remove it from the laptop and get the number off of it. Then you can go and Google the number to find a reasonably priced replacement.
Hope this helps you.
Dec 26, 2010 | HP Compaq Business Notebook 2230s
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Oct 27, 2010 | HP Mini 1000 Netbook
My Dell Inspiron 1525 is now around 2 years old and works only for 15 or 20 minutes after plugged out.Also on battery symbol, it displays a message saying "consider replacing your battery" and show a cross...
Don't worry just replace the battery of the laptop and your problem will be fixed.
It is because your laptop's battery has become old.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 14, 2010 | Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Inspiron runs on ac power but not battery
Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
Jul 20, 2009 | Dell Inspiron 1501 Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Compaq Presario CQ61-310US Laptop Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
