Question about Garden
I have just inherited the same mower that has not turned a blade for two years. There is no fuel cut off with this machine. I assume it is sparking? Take of the fuel tank and carb. Remove carb from tank and clean small intake filters.. Remote main jet a blow everything through. Replace all and prime cylinder with small amount of fuel and try it. There is also a square cover on the side of the carb that holdsthe diaphragm as it is a fuel suction machine.carefuly remove cove and inspect,diaphragm may be worn or damaged and not drawing fuel from the tank.
Posted on May 26, 2013
SOURCE: lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Posted on Oct 21, 2008
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
SOURCE: fuel leak on craftsman pushmower with Honda engine.
Sounds like you tilted the unit enough to cause the float in the carb to open too much and therefore, the needle valve inside is stuck.
Remove the bowl and let it resit itself and then re install the bowl. If that doesn't work you may need to purchase a new kit for the carb to get the needle valve. If you find a small minut ring around the face of the needle valve replace it. That's why it's gonna leak. Good luck
Posted on Aug 02, 2009
SOURCE: my lawn boy 6.5hp mower isblowing fuel out of the muffler
Maybe it's a stuck float valve or a bad float. Had a similar problem on a TORO rider but that turned out to have a pin hole in the brass float, it filled up with gas and let just about the hole tank through the muffler. I changed the brass float and still running to this day! Note: your float may not be brass if it is a newer machine it will be plastic.
Posted on Oct 01, 2009
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
Posted on Nov 28, 2010
Sep 03, 2012 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Aug 04, 2012 | Garden
May 25, 2012 | Troy Garden
Aug 18, 2011 | Poulan "Poulan" Push Mower
Take a look at this tip I wrote on the no start problem. It should help you.
Jul 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 09, 2011 | Garden
Jun 02, 2011 | Mtd Garden
Nov 03, 2010 | Garden
Oct 07, 2009 | Garden
Apr 04, 2009 | Garden
Apr 24, 2018 | Electric Garden
Apr 23, 2018 | Garden
320 people viewed this question
