Question about Garden
Benchmark fiberglass front door molding around oval leaded glass has cracked and has caused the whole oval to slip down. Can the molding be replaced? Can provide picture if needed.
Steel entry oval ring holding in glass has been knocked out by large dog. The glass is still in tact but the oval molding is damaged. Can just the oval molding be ordered and do you have installers to perform the work? Thanks!
Posted on Oct 06, 2012
Front top at the curve is buckled? Why
Look to see if any staples or fasteners are loose. A cracked piece of lumber that the fiberglass attaches to will let it buckle. If you have J molding covering the end of the fiberglass panel, pull out the plastic center strip and add more screws where it is buckling.
Jul 05, 2015 | Cars & Trucks
How to fix crack in door?
I believe these are plastic doors, so you can plastic weld a repair, or rough it up with sand paper and used fiberglass product such as "kitty hair" and glass mat, sand smoth and paint. Better still, there are tons of these in junkyards. Find one the right color and replace the door.
Jul 16, 2014 | 2006 Saturn ION
How to stain fiberglass entry door?
You cannot use regular stain on a Fiberglass door. Stain is made to soak into wood. It cannot soak into Fiberglass. It will peel right off in several months depending on the weather. A solid stain may would work for a while, but it will not hold up as well. Whereas stain is made to soak into wood, paint is made to sit on top of surfaces. There are some nice paints that look like stained wood if that is the effect you are looking for. But if you want the new finish to last on your door, use paint. Make sure you clean the door thoroughly with a degreaser, prep solvent or paint thinner
Apr 29, 2014 | Jeld-wen Door. Ascot 3/4 Lite Oval Primed...
Mold on gaskets I like my Samsung refrigerator
Have you tried Clorox along with a fungicide? Mold usually forms on a moist surface. Is there any air leaks around the door seals? Sea Breeze
Aug 08, 2013 | Samsung Refrigerators
My friend offered to strip my canoe paddle and recoat it as weather/mold has worn off original coating/poly? However, he put stripper ALL over the paddle!, causing the fiberglass to come off the...
I suggest 6 or even 4 oz. cloth, well soaked in resin and trimmed to fit. Sand it down smooth as soon as it is cured. An extra layer around the tip (last 2-3 inches only) might be useful if you really bang it around a lot, but every bit of weight you add will be weight you have to swing 500 to 1000 times per mile.
Sep 22, 2010 | Werner Paddles Boating
How to remove the fiberglass cap under the vinyl roof on my car?
The car has the entire vinyl roof attached not to the roof but a fiberglass sub roof. To remove well that's the upholstery people secret and why they charge 700. To remove and replace after the glass co. Comes in and replacing e's the rear glass. There is a patent on it and different mold for every car.
Feb 10, 2010 | 2001 Lincoln LS
Scanner does not scan. It seems to be jammed, stuck.
Thanks for your interest. The problem appears to be in the hardware - so I'll
be visiting the store where it was purchased, to either fix it or replace the scanner.
Regards,
Richard
Dec 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Light and door spring
I had a tension rod break in my door as well. There are two of them that cross forming an X and you can see them when you open the door and look in the crack. Fixing them is very easy once you get the outer panel w/ glass and the black molded plastic piece off. WARNING, when you open the door there are two screw on the inside top part of the door assembly. THEY ARE THE ONLY TWO SCREWS HOLDING THE ENTIRE FRONT PANEL/GLASS ASSEMBLY IN PLACE. I found this out the hard way. When the 2nd screw disengaged the whole assembly came crashing down shattering the glass and nearly cut off my toe. Be very careful when taking off the outside panel!!!
Next challenge...the black molded piece that also needs to come off. To remove this take off the piece that surrounds the exhaust tube to get at two screws that are directly underneath the molded plastic piece. After getting that off you have access to the two rod and can get them installed without to much trouble.
Again, be very careful when removing the front panel. My repair went from an 18 dollar tension rod to a $200 dollar front panel and nearly cost me a toe (yes, I was barefoot).
Aug 07, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Hey, Buddy!
Well the mold is caused from the door being shut after you arte finished with the use of the machine. it traps the mouisture inside..To solve this use some bleach and water wipe it down around the door seal..then after each load just crack the door open this will allow air to dry out the inside and stop the mold
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Garden Logo
82 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
