Question about Hi-Touch Imaging HiTi 640ID Thermal Photo Printer
When insert card into printer slot the card error is showing how to solve
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
I have an HP 4000N printer that is showing an E10 error. Can you advise what the problem is? Thank you.
EIO Error: Has to due with the additional card or hard drive on the back of the printer. If it's a networked based printer try the following:
Power off machine and unplug power cord.
Remove the network card from the EIO slot
Remove the cover from the other EIO slot (either below or above) and insert the card into that slot.
Power machine back on, see if error comes back.
If error is still present:
- Remove the card turn machine back on and see if the displays comes to ready.
If machine does come to a ready state than I would recommend:
- Replace the Network Card
If after replacement of card and attempted both EIO slots. Then you will need to replace the formatter.
Hope this helps!
Mar 07, 2011 | HP LaserJet 4000n Printer
When I insert a SDHC memory card in printer,I get card access error message.How can I solve this problem?
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
Jul 09, 2010 | HP Photosmart 375 InkJet Printer
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Im having no signal to the monitor and a vga error on the mother board try everything
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
Mar 12, 2010 | Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX...
Printer Locked
The printer in question comes with a smart card that must be inserted in the slot neer the lcd screen. If you have lost your card you will have to contact fargo to unlock the printer.
May 31, 2009 | Fargo HDP820 Thermal Printer
How do you transfer pictures on thememory card inserted in the print to the computer?
if you plug the memory card in the slot. software will see it and start automaticly.
May 30, 2009 | HP Photosmart C4480 All-In-One InkJet...
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Hi-Touch Imaging HiTi 640ID Thermal Photo Printer Logo
110 people viewed this question
Top Hi-Touch Imaging Office Equipment & Supplies Experts
John Hong
John Hong
Pierre Legault
ray gallant
Are you a Hi-Touch Imaging Office Equipment and Supply Expert? Answer questions, earn points and help others
