Question about Plumbing
Sottini Globe Bath filler tap, requre a a new cartridge.Where can these be obtained?
2 Suggested Answers
  • 44 Answers
SOURCE: need to fit ideal standard lever cartridge to mixer tap
hi you 1st need to isolate both hot & cold water supplies to bath.lift the lever up & underneath the lever you will see s screw unscrew it & be careful not let it go down the plug hole, so a good idea at this point is to put in the plug!!!
Once the screw is loosened you will be able to remove the lever.
then there is a cover which will need to be undone & removed seeing as its gold you will have to be careful undoing this as it may be stiff, sometimes a few taps with the endle of a srewdriver handle will loosen it enough so you can remove it. once this is removed you will gain access to the hexagonal part of the cartridge, so yo uwill need to have the appropriate spanner or adjustable spanner. you will need to hold against the tap when undoing it so as the whole tap body doesnt move.once the cartridge is removed the new unit can be fitted in reverse order.it sounds simple but being Gold you have to be careful you dont damage it whilst attempting to remove the old one. Tip put some silicone gtrease around the o rings on the new unit as it will make it easier to remove if you ever have to remove it again?
Kindly
Richie
Posted on Dec 15, 2008
Need to replace cartridge on hansgrohe talis high arc faucet
The cartridge should come with instructions on replacement. The part number for the cartridge is 92730000. It is available through your local dealer or online dealer. If you need further help with obtaining the cartridge or installation feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Oct 04, 2012 | Hansgrohe 32070821 Talis S Single-Hole...
Cannot get the hot water handle off. Have remove the collar and the base, handle will still not come off
im not 100%sure on the particular set of taps you have ,but by looking at the picture on screen ill hazard a quess.by the way im a plumber .under the lever for hot water tap is a cone shaped shrowd .narrowest at its point where its in contact with lever and broadest at bath top end .this shroud will screw off .in the middle of the lever you pop off insert and unscrew cross head screw and then back off shroud ,the tap spindle should then be exposed
Jan 19, 2011 | Grohe 25.506.EN0 Geneva Roman Tub Filler...
The hot water is not coming out the tap in the bath,only slight dribble,it wont turn on fully also.
possibly some sediment caught in the cartridge or stem. put some water in a bowl or sink, turn the water off to the fixture, remove the cartridge or stem, flush the cartridge or stem in the water, check for blockage inside valve body, replace parts, turn on water.
Dec 05, 2010 | Home
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
Bath sink hot tap doesn,t turn open fully
You need to replace stem/cartridge assembly depends on the brand if it is a stem or a cartridge
Oct 02, 2009 | Plumbing
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Need to fit ideal standard lever cartridge to mixer tap
Kindly
Richie
Dec 15, 2008 | Plumbing
Restriction code
1. the set has very less backup of battery. Due to poor battery backup it could not run for full day. it requres charging thrice for 24 hrs working.
2. pl provide more ring tones.
Mar 06, 2008 | Nokia 6300 Cellular Phone
Plumbing Logo
257 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
