Question about Sharp CD-RW5000 Shelf System
When trying to record from a tape to cd, when I hit cdr record the cd which is lit up blinks a couple of times and then a ? mark shows up. So I can not record. When I originally load the cd to be recorded on it blinks and loads and lights up like everything is ok. But gives me the ? mark when record is hit. I used a cleaning disk but still having the problem.
    Brigadier General:
  • 8,546 Answers
Http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/Audio/Manuals/Archive/aud_man_cdrw5000.pdf
Have you looked at the manual? This unit only records on CD-R AUDIO blank media. (Page 44)
Posted on May 20, 2011
My Yamaha CDR D651 appears to dislike new 50x maxell CD-r discs saying not audio. Works fine with 12x discs. What's wrong? Rowan
you probably have regular cd-r disks that cannot be recorded on in this unit. You can only use disks marked "DIGITAL AUDIO" for recording
Sep 16, 2014 | Yamaha CDR-D651 2-Disc CD Recorder
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Apr 03, 2014 | Marantz CDR420 CD Recorder
Power failed in middle of a recording session when the machine was in Pause mode. How can I recover the recorded file?
You can try computer software like Nero or Roxio and finalize the disc as it is. This is exactly why I had advised Churches that went from reliable cassette tapes to CDR to put UPS units on the CD recorders as they do not react too well to power outages. If you were using an Open Reel there would be very little loss of the recorded signal.
Mar 24, 2013 | Marantz CDR-300 CD Recorder
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
CDR200
Push CD Sync...when goes into it....push record or pause....like a double tape deck.
Jul 11, 2008 | Classic Electronics CDR201 CD Recorder
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Problem with Sony RCD-W1 CD recorder
'No audio' comes up when you use the wrong type of cdr in the drive. You need a 'consumer audio' or 'music' specific CDR and not a generic computer cdr to use in these units.
Sep 27, 2007 | Marantz CDR631 CD Recorder
Sharp CD-RW5000 Shelf System Logo
83 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
