Question about MotorGuide FW40 FB 42" 12V FLXMT Trolling Motor (MotorGuide)
How does the foot feed work? There is a dial with a circle, one dot, two dots, three dots, four dots, five dots. There is a switch that has a circle, a T, and a rabbit, what do those mean?
  • kstrickla447 May 20, 2011
    Thank you for your help. Our son bought the trolling motor and there was no instruction manual.
    You answered our question, thank you again...................... Kathy
    Brigadier General:
  • 3,917 Answers
Rocking the pedal forward and back turns left and right. There is a button which is pressed on the pedal to turn it on. Speed is controlled by a roller wheel on the pedal. Lift your foot off the pedal and it will turn off. Please check the bellow instructions for the detailed information of its movement.
For the forward movement first sit on the seat that is closest to the trolling-motor foot control. Choose the speed setting on your trolling motor. The trolling motors have numbered speed control on the foot controls ranging from slowest speed starting from 1 to 5 or 10 which is the highest speed. Now press the "Constant" or "Momentary" control switches on the foot controls, if you check they are placed on the sides or ends Press them with the end of your shoe or toe. This action will cause the trolling motor to turn on and Put the boat in motion. Some trolling motor models only have a "Constant" or "On" button. As the words suggest "Constant" will run the trolling motor continuously until you turn it off again, and "Momentary" will run the motor for a short time.
For the left and right movement press the front foot control which is also called "toe down" to turn right. Press the rear foot control down or "heel down" to turn left. Now release the foot control to let it go straight. To continue going in a straight line just do nothing the machine is set to go straight by default. But you need to have the foot in pedal to get it going.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 20, 2011
  • e-Guru
    e-Guru May 20, 2011
    Hi
    Thanks for the appreciation and we are happy to help you.If you are satisfied with this answer kindly accept the suggestion and rate it fixya.Have a good time.
    Thanks for contacting fixya.com
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
Where can i find watch dial for shc041
Firstly, what is a shc041? The cleats are called dial feet. They orient the dial to the movement so 12 is always at the top. When they break the dial spins around. Three solutions. Anew dial from the manufacture. A used dial from another watch, maybe from a popular auction site, or "dial dots". Small adhesive dots used to adhere dials with broken dial feet to movements. Sometimes successful, sometimes not. A forthis to send the dial to a dial refinishing company and have new feet soldered on.
Oct 19, 2011 | Seiko SHC041 Watch
WHEN I TURN THE POWER ON, THE SPEED SELECTOR IS THE ONLY THING THAT COMES ON. IT HAS 5 DOTS THAT SELECTS HOW FAST THE CHAIR WILL GO. ONE DOT BEING THE SLOWEST AND 5 DOTS BEING THE FASTEST. WHEN I TURN...
abrams I would start with the batteries. If you have a digital voltmeter set it to 200 volts dc and plug the meter into the 2 outter holes on the charger port located under the front of the joystick. Fully charged the voltage should read 24-27 volts. If you are not getting this voltage then replace the batteries It requires 2 U1 batteries. Hope this helps
Sep 14, 2010 | Jet 3 Ultra Power Chair
Timing marks on a 1996 ford escort 1.9L SEFI 4 cyl motor. I am triing to replace timing belt
im asuming all repairs went well,one,get a clean rag and wipe the gears and i mean wipe them clean two wipe and clean the plates behind them, three,lets start at the top find the dots on the gear you will see a tiny dot/indent four, look at the plate/caseing behind it and you will see another dot/indent,line them all up GEAR DOT to BACK DOT,five keep them in line and dont move them once you a satisfied all is in place and lined up and i mean lined up there is no room for error,fit belt and tighten .adrian,,,,,,,,
Aug 15, 2010 | 1996 Ford Escort 4 Door
Does this require dot 3 or dot 5 for the clutch system?
hello there:
this truck calls for the dot three fluid but will not hurt if you use the dot five it will perform just as well this will be a personal call on what you would like to use hope this helps you out thanks sincerely D.Jones
Jun 08, 2010 | 1997 Mazda Pickup
The feed dog is not grabbing the material or the presser foot pressure doesn't seem to be working. I have a Viking 6000 SL sewing machine, Model 6460.
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Oct 23, 2009 | Husqvarna Viking 1
Plastic foot. I'm missing one out of four. Emerson Model MW8779W. Need one. Can you help?
Sadly, no. You may find a similar one at Lowe's/HomeDepot/similar, or you may want to remove the other three and replace all of them with the same type. Would those stick-on felt dots work for you?
Regards, --W/D--
Aug 01, 2009 | Emerson Microwave Ovens
W123 holding some water and dial keeps spinning around checked the filter all clear
may be a blockage in the sump hose or pump feed hose or the pump itself may be faulty. the dial will click round to tell you there is a fault. to reset turn the dial onto every DOT and turn on for 10 secs then off and onto the next dot it will flash for a couple of seconds to confirm.
Mar 17, 2009 | Indesit W 123 Front Load Washer
MotorGuide FW40 FB 42" 12V FLXMT Trolling Motor (MotorGuide) Logo
179 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
