Question about Philips Televison & Video
When pressing the on / off button, the tv will not stay on, it powers down immediately
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both - in your case, it's most likely the power board section.
Any caps in these sections (or any other for that matter) that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't, and it may already be at that point !
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, and it spans most major brands including Philips.
The parts are cheap, and skill required is minimal.
Posted on May 20, 2011
Youtube video not play in my samsung gt-c3510 corby pop
Posted on May 25, 2011
2 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: Lc-c323-4u aquos sharp tv on
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Posted on Jul 07, 2011
I have a ONN universal remote for tv. What are the codes for an Emerson. Tv
Try these, and hope one of them works for your TV:
00017, 00154, 00171, 00178, 00451`, 00463, 01394, 01661, 01864
Jul 18, 2014 | Televison & Video
Tip
Lamp Time Reset for Samsung TVs
This is a quick reference guide to show you how to reset your
Samsung DLP TV’s lamp hour meter or hour counter.
Resetting the counter is a very simple procedure.
Begin with the TV powered off
Point your remote towards your TV
Press:
Mute + 1 + 8 + 2 + Power
Your TV set should now say “Loading Factory”
Browse down to “Option” then press Enter
(or the right cursor button)
NOTE:
The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. I think that’s a better way to do it.. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button
To exit the service menu, hit press the EXIT button or just turn off your
TV (remember not to turn on your TV immediately afterward!)
on Mar 24, 2010 | Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Need codes to program a dishnet remote to a emerson tv
Turn on device you want to control (TV, VCR, DVD)
Press and hold the CODE SEARCH button until the red indicator light remains red, then release
Press the desired mode button (TV, VCR, DVD) and release
Press the POWER button slowly, but repeatedly
until device turns off. While doing this, the red indicator blinks then stays lit
Once the device turns off, press and release the Enter button to install code. The remote should be synced to the device.
Another view:
Someone on another board pointed out that with some newer models you do not need to press the CHANNEL UP button repeatedly. Rather, you press it only ONCE, and the device will cycle through all the code possibilities. When the TV turns off, it means that the proper code has been found. Immediately press the Enter button to install that proper code. This method (and no other) worked for me.
Jun 20, 2010 | Emerson LC320EM8 32 in. LCD TV
Just replaced the lamp in my Samsung DLP and still no picture just audio. Heard something about a code to reset timer / hours counter. Any Ideas/
counter. Resetting the counter is a very simple procedure. Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
Apr 16, 2010 | Samsung DLP HL-P5663W 56" TV
I need the codes to program my Innovage Jumbo Universal Remote for Dynex television
As there are no specific codes for the Dynex TV you have the choice of either using the Auto or Learn method. The following are instructions for both:
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. *
Mar 02, 2010 | RCA RCU600M Remote Control
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
Televison & Video Logo
318 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
