Question about Garmin GPS
I have a garmin 3210 on my boat. I will b driving in the bay and the screen will show sonar service lost and the depthfinder will not show any number and the sonar screen will freeze. Anything that I can do to fix this? Thanks Josh
5 Suggested Answers
SOURCE: 310 c garmin gps on boat not working
Hi, 673king, My Garmin is c330, but I think that all GPS's of this nature are programmed only for roads -- not bodies of water. I haven't updated my 2-yr.-old-Garmin yet for new maps, but what you describe concerning the red question mark is exactly what I get when I am on a road that was constructed after my Garmin was programmed. Since the GPS can't find the road in its memory, it merely has a red question mark until I get onto a road that the software recognizes. It then operates as usual.
Posted on Aug 10, 2008
SOURCE: Garmin Nuvi 250w screen freezes when attempting to
I have the same problem as you. How you solved it?
Posted on Jul 18, 2010
gopakumarg43
  • 75178 Answers
SOURCE: My Lowrance LMS-332C GPS was
Hello
If the GPS works and sonar section does not work at all, check the followings.
1# Check the power cable's connection at the unit. Also check the wiring
2# Make sure the power cable is wired properly. The red wire connects
to the positive battery terminal, black to negative or ground
3# Check the fuse.
4# Measure the battery voltage at the unit's power connector. It should
be at least 10 volts. If it isn't, the wiring to the unit is defective, the
battery terminals or wiring on the terminals are corroded, or the battery
needs charging.
Check whether there have any wiring break, loose. During servicing the boat, there is chance to get the wiring of sonar to sonar sensor at the botom of the boat may have damaged. Check these. OK.
Posted on Aug 29, 2011
  • 4 Answers
SOURCE: Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
Posted on Dec 02, 2011
I want the screen split showing chart/sonar with trails on the chart. How do I do that?
I don't know what unit you have, but here goes.. go to "pages" scroll to map, scroll to "map with sonar"..hit enter..
Jun 13, 2017 | Boating
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
Jun 07, 2016 | Garmin Color Fishfinder 160c
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
On the GPS Garmin the radar screen shows our boat turned the wrong way. How do you turn the boat around on screen?
My husband moved the boat slightly and it seemed to correct the radar screen somewhat. He is working on the whole boat at present so didn't want to take it completely for a drive down the river. If we have further problems we may call in or use the web site.
Thanks,
Farrar
Jun 23, 2009 | Garmin Gpsmap 4208 Network Bundle
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
