Question about NorStar M7208 8 Phone (NT8B30AB93)
Calls being forwarded to voicemail when they should be ringing. The phone display says FORWARD>2251. How do I turn that off?
    Problem Solver:
  • 19 Answers
Feature #4 .. if that doesn't work, then FEATURE 984 ...
Posted on May 20, 2011
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
Sep 19, 2014 | Samsung Cell Phones
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Phone doesnt ring, it goes straight to voicemail
Hii pls chk for all saved contacts, the option "send calls directly to voicemail" is unchecked.
and also verify that the following are unchecked under: Call Settings-->Call forwarding
1-Forward when busy
2-Forward when unanswered
3-Forward when unreachable
If the problem still occurs contact your customer care executive.
Jun 07, 2012 | HTC Status
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
I have the same problem. Any ideas??
Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I have a 4025 Not Forwarding to VM?
The Call Forward is set up by using the BLUE Super KEY located below the display. You have to know the Voicemail Pilot Number to be able to complete the programming. Basically you press " superkey ", say NO to the prompts until Call Forwarding comes up, say YES to Call Fordward, choise the type of forward you want ( always, no answer, busy, busy/no answer )dial in the voicemail pilot number, press save and then press the superkey to exit programming. Good Luck
Aug 01, 2008 | Mitel Superset 4025 Corded Phone...
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
NorStar M7208 8 Phone (NT8B30AB93) Logo
152 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
