Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell 7901 proheat service manual
My deep cleaner no longer spays water so i removed the cover to see if the hoses weir kinked or if the pump was leaking so i removed the pump but i don't know if i may have the hoses switched around the water trickles out of the hose for cleaning the furniture
  • 1 more comment
  • neverdisturb Jan 18, 2009
    i need a service manual for correct complete reassembly of bissell 7901 proheat carpet cleaner, and i cannot seem to find answers on this site which i am using for first time. how do i get online service manual for bissell and how do i get to answers on this site please?
  • johnsonukboy May 11, 2010
    need
  • Anonymous Mar 22, 2014
    how do the hoses from pump assemble?
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
Posted on Sep 01, 2008
  • 502 Answers
You will get the repair manuals from manualfox.com
Just send them a request.
Posted on Sep 13, 2010
My machine won't **** up water. which part do i need to replace
Posted on Sep 08, 2008
Dont buy a junkie bissell have got 4 of them sitting in the vac shop with the same problem the best way to fix them is to throw them away and buy a roayl procision from DIXIE VACUUM CENTER IN LAWRENCEBURG TN
Posted on Sep 04, 2008
SOURCE:
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Machine will not dispense water or cleaner
That means that the pump belt is worn, stretched or broken and it needs to be replaced. Here is a link to the belts you need and the manual.
Bissell Proheat Belts and Manual
Dec 29, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Pro Heat 7901 will spay through hose but not the floor and red flow indicator will not spin. So we took the housing off and after unclogging a hose running to the hearter, my husband unhooked the...
I borrowed my friends bissell to clean my carpet. It's the 7901. He brought it over and told me that it only sprayed out of the attachment hose. He said he couldn't figure out what was wrong. I'm no vacuum technician but, I am a mechnic. I decided to open her up and check it out. After about two hours it was back together and working. The reason I replied to your e-mail was because we have the same problem. I couldn't find an answer to this problem on this site so I will tell you what I found and hopefully it will help you. In removing the cover where the red heating light is, there is the heating unit for the water. In my case it is silver and it will get very hot so be careful. Notice that there is two water hoses connected to it. I removed this heater and found one of the connectors where the water hose goes was clogged. I took the back off the heater and used my air compressor to blow out the connector, and sure enough something flew out. Hope this helps. [email protected]
Sep 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
2,050 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
