Question about Protron PLTV-32 Television
Volume makes a cracking noise. sometimes there is no volume,so i have to slap the back of tv to get sound back
  • 1 more comment
  • ann8622 Feb 02, 2009
    Having the same problem
  • jonwicke Feb 17, 2009
    crackling noise and screeching sound after about 15 min of use
  • jojostv Apr 15, 2009
    where is a repair center and whats the cost
    Problem Solver:
  • 53 Answers
Hello Sgarmekiss:
That issue sound like you will need to have your small signal board repalced by a repair center.
Posted on Aug 19, 2008
Volume makes a crackling noise when tv first comes on. (10 to15 min.) Could you advise me what to do?
Posted on Feb 15, 2009
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Knocking (Pinging) noise heard when car is in drive
check the vehicle knock sendor, are u using the right grade of gas, and oil for u temp zone
Jul 21, 2009 | 2006 Suzuki Forenza
Picture is really light in color screen is white
It sounds like you have bad solder joints in the tv. If you resolder the boards in the tv, it sounds like it will be fine. When you are slapping the tv, it is temproarly making contact again and fixing the picture..
Jan 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Mitsubishi TV
Hi jmvca:
Most likely the tuner is starting to fail. When it is first turned on, tap or slap the side of the cabinet to see if it makes any difference.
The set will have to be repaired in a shop when it goes out completely.
Feb 22, 2008 | Televison & Video
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Apr 24, 2007 | RCA 27V520T 27" TV
Static comes from speakers
I think it's a grounding problem. Actually, it's a necessity for all audio-video equipments to get grounded properly. If you don't have a ground connection in your AC plug, your receiver will collect more and more static electricity. As a matter of fact, it decreases the sound quality that you can get from your equipment. I think that the effect of your reaction (slapping the receiver) isn't coincidental. When you touch any metal surface on your receiver (even while slapping) you condact the static electricity to the ground. I've had a same sort of problem with my receiver. Especially when I connected my laptop computer to the receiver, I heard an annoying distorted sound from the speakers. I found out that it was ground loop, which occurs when the negative (common) signal of the source coincides with the one of the receiver's. As a solution, I grounded my amp, changed all wires with new and shielded ones, and purchased an AC filter. Then, I got rid of the noise. I have to say that the AC filter (Belkin Pure AV Surge Protector, it also includes an AC signal filter)benefited me the most.
May 03, 2007 | Aiwa AV-D67 Receiver
Protron PLTV-32 Television Logo
180 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
