What is the load capacity of the Whirlpool LLR6144ANO?
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
What is the capacity of washer model GHW9400PW0
Whirlpool GHW9400PW Washer / 27" Duet Front-Load Washer w/ 3.8 Cu. Ft. Capacity, 13 Cycles & 1200 RPM
Feb 05, 2010 | Whirlpool GHW9400SU Front Load Stacked...
What is its capacity
Overall home/domestic washers have similar capacities:
Front loaders: between 15 and 20 pounds capacity.
Top loaders: between 10 and 12 pounds capacity.
The best way to determine if you are not overloading your washer is by loading your clothes in the washer making sure it is loosely full of clothes "do not push the load down" to make room for more.
Aug 30, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Apr 19, 2009 | Maytag HAV2558 Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
