Question about Toro Garden
I have a old Toro riding mower Model # 56155 that has a flat tire on the back, I've taken the bolt out that I thought kept the tire on...my question is HOW DOES ONE GET THE TIRE AND WHEEL OFF THE RIGHT BACK OF THE MOWER?????....THANKS
  • Roy Cagle
    Roy Cagle May 20, 2011
    You may have to treat the assembly the way tire guys do a big truck tire in the field, by prying the flat tire off the rim. If you do, use a flat-bladed crowbar. That will allow you to at least get tthe tire off the rim. Try that and post back as I don't know what the wheel/axle configuration is on those older units.Toro has some diagrams on the net. I found this, but don't know if it will help. http://www.partstree.com/parts/?lc=toro_...
  • 3 Answers
SOURCE: troy bilt riding mower
Have you tried checking your fuel filter or your air breather?
Posted on Dec 09, 2008
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
  • 13 Answers
SOURCE: I have a Toro personal pace mower. Model 20017 The
im assuming you dont here any grinding, start by tightening the cable ( loosen the cable mounting bolt slide the cable towards the engine, make sure you leave some play in the cable so its doesnt engage constantly and re-tighten ) this is most likely your issue however if you re-test and get grinding you either need new drive gears and wheels, new transmission or possibly both, you said it does something just not powerfully this pretty much rules out your belt, highly doubtful its that worn out and if it came off of a pulley it would do literally nothing, however if you tighten it and the drive is almost normal but still weak you do have a worn drive belt
Posted on May 20, 2011
Can't remove rear tire from riding mower
Have to thread the funny piece of metal off!
Aug 05, 2016 | Garden
The front tires on my Toro keep loosing air and are very often flat. What can I do to solve this problem?
They are most likely loosing air at the seal at the rims. That happened to me. I bought some inner tubes and problem solved.
Sep 20, 2014 | Toro Garden
Wont start been idle 4 months 9 months old unleaded in tank 4 months
If you didn't kept gas in carb. and didn't add stab-loc. You need clean the carb.
Mar 18, 2014 | Toro Garden
My toro mower won't start. new air filter, new spark plug, etc. could it just be stale gas?
The Toros have a Tecumseh engine and are famous for this. I'd suggest you do a thorough cleaning of the carburetor, but there is a little known secret that I've learned about this particular carb. Pull the bolt from the bottom of the float bowl on the carb (1/2 inch wrench; the "main jet"). Be sure that all the little holes in that jet are clean and you can stick a wire thru them. There is a microscopic hole at the very top of the threads on that brass bolt that often gets clogged and your mower will not start. I use the wire from the needle valve inside the carburetor to stick thru it, as it's about the only thing that'll fit. (note: if you have 50 year old eyes like me, you can't even see this hole w/out specs). Hope this helps and best of luck to you. (also, be sure you put the float bowl back on the right way; there's a bevel in the back that needs to go toward the hinge in the float or the float won't work. Learned that one the hard way as well. )
James
Aug 20, 2011 | Toro Power Lawn Mower
Flat front tire on toro riding lawn mower
you need to take your pliers and straighten the curved end to remove the pin and then pull the wheel off. Be sure that your bend the pin back to the way it was after you re-install the wheel. hope this helps you
Oct 05, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro hmr 1200 and one rear tire drives one won't
some of them has a key that helps both tires spin but alot of riding mowers have only one tire spin but not all it could be in the gears it's self
Jun 07, 2009 | Garden
Garden Logo
80 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
