Low speed 15kb . how to speed fast ? - Computers & Internet
    Master:
  • 341 Answers
Hi you can try 3G broadband high speed connection. If you are use a data card then change your data card and purchase high speed supported data card. Beacuse speed is also depends on the Modem.
Thanks
Posted on May 20, 2011
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
Why does it occasionally experience complete, temporary loss of electric when coming to stop?
Sounds like the idle speed of your car is too low, then the alternator cannot produce enough voltage for any electrical devices. When idle speed is normal or much higher, power will return to normal very fast. It may be that the idle air control valve is dirty or defective.
Aug 18, 2015 | 2004 Chrysler PT Cruiser
I have not installed any program But my N73 shows "memory low delete some data" some times it shows enough memory i.e. up to 21mb, and some times as much low as 15kb please help
That means your phone memory is full,,,or sometimes it occur due to malfunction of the running software.So my comment is just flash the phone.If you do not know request here Jordan Fakharang Raingam
Jul 22, 2011 | Nokia N73 Cellular Phone
What aere the primary settings on the high & low speed screws on a sears 42cc chain saw engine?
start off with the low speed screw turn it right in then undo it 1+1/2 a turn start saw up and screw slow running screw in or out a little bit at a time till the saw ticks over,,then give the saw full throtel and screw the fast screw in or out till the saw is reving as fast as it will rev at
Mar 25, 2010 | Garden
1985 gmc k1500 wipers only move at 1 slow spped, interminttent doesnt work at all. How fast is fast and why is fast not working?
Slow is the same speed as 'mist'. Mist is when you twist the control arm backwards to induce a single swipe. If you hold it, you will run the wipers in low speed. Fast is faster than that. Probably by 30% or more.
Turn the wipers on high speed. Wiggle the connector at the wiper motor. If the wipers run sporadically as you wiggle the connector, you either have a bad connector or a bad circuit board on the wiper motor.
Jan 15, 2010 | 1985 GMC K1500
Coleman outdoor furnace/AC blower speed too fast
You are right slow for heat and fast for A/C. Here are the blower speeds black is high blue is med. and red is low if you have orange it would be med low. Look on the control board and see what color wire is connected to heat and let me know if you have something other then control board. You can take the wire that is on park and swap them around. ken
Jan 11, 2009 | Heating & Cooling
Blower speed too fast
The furnace should be a 3 or 4 speed motor in it. On the circuit board there are places maked heat and cool. If you are looking for low the red wire should be plugged into the heat designation. make sure unit is unplugged before changing
Nov 22, 2008 | Goodman GMS80453ANA Open Flame Mid-Size...
My fan is blowing, but if i put it on high it does blow fast like it normally does.
the connection order would have got reversed low speed connection has been given to high terminal and high speed connection has been given to low speed terminal thats y this problem this is nothing to worry
Jul 27, 2008 | Hampton Bay 24002 Ceiling Fan
Fan speed too fast
Is there a light switch control or just straight power to the fan? They do sell "Fan" controll switches just like a regular dimmer, but for a fan. If there is just straight power u would still be able to install a remote that could lessen the speed. Even if it is just pull chains. the remote would have three speeds and if u kept the pull chain on low, maybe the low remote speed could work.
May 22, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
