Question about Peg Perego John Deere Gator HPX Ride on Toy
Right side makes a grinding sound like its the gears. what can i do
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You need a new gear box, let me know if you would like me to order you one
Posted on May 16, 2012
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
Symptom: Grinding sound.
This could be either your drum cartridge or your fuser unit.
Take your toner cartridge out and look right up front where the drum cartridge empties 'waste toner' back into the toner cartridge.  There's a little flap there that slides back and forth on the very end.  Slide it back and see if toner is packed in there solid.  If so, vacuum it out.  Then you'll have to replace that drum.  Sometimes you can salvage them by cleaning out all the waste toner, but usually the gear in back has already stripped and it's no use.
If everything looks fine with the cartridges, it's probably the fuser.  You can buy a new one here:
http://www.acrat.com/xeroxfuser.htm
The fuser is that part of the machine that gets real hot.  If you open the right side door, it'll be right close to the top.  There are usually 4 screws holding it in place.  If you take those screws out, you should be able to hold it away from the machine while it's running (you'll have to cheat the door).  If the grinding stops as soon as you pull the fuser away, that's probably your problem.
Let me know if any of this sounds too technical.  eric AT essonline.us
Oct 31, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
The printer makes a grinding/squeaking sound when printing. The sound seems to be coming from the top rollers at the back of the printer.
This sound possibilly from top of the right side, open right cover refix the deplex drive gear set if not presists, inter change the duplex drive gears(these two similar gears drives white & black gears easily locatable).....
Sep 06, 2011 | HP LaserJet P2015dn Printer
When I was driving my 1996 Geo Prizm at around 25mph, I heard a popping sound and then the grinding started like it was rubbing metal to metal. When I turn to the right, it sounds louder. I had the brakes...
CV Joint went out. since it gets worse when you turn right it is most likely an inside drivers side CV joint or the out side passenger side. The popping sounds was probably the dust boot popping from pressure build up which should make it simple to locate since you just need to identify the boot with a tear in it.
Feb 28, 2011 | 1996 Geo Prizm
My xerox machine is making really loud funny noise that are unusual, it makes the noise while it is warming up and until it prints, it is out of the ordernary sounds that we hear from it. it is more of a...
could be a few things... take out the drum and make sure the toner is put back in. then keep the right side door open and push the silver metal flap down near the back of the door opening (its the interlock that tells the machine the right side door is closed) and see if the noise occurs. if it does then you no its not the drum. so u can reinstall it. try to pin point the source of the sound with the right side door open. could be one of the many gears in back or the fuser (which is above the green colored drum) 4 screws and one wire harness takes off the fuser and u can physically inspect to see if the gears are missing any teeth or the bushings are broken. if all looks well then reinstall turn machine around and take off the back cover (6 screws) wiggle it off and turn the machine on and look closely at all the gears on the left(looking at the back) top side. when it starts it warm up process check to see if any gears are making the sound or cracked. if those gears are shot u mught need a new main drive assembly which is really difficult and time consuming to repair.
Jan 17, 2011 | Xerox WorkCenter 4150 Black and White...
My 2006 Ford F-150 has a grinding noise in the driver side front wheel. when the front end is jacked up and in 4 wd the right side is locked in but the left side will spin freely and make a grinding sound.
Sounds like you have a IWE that the gears are ground down, or a bad vacuum line to that side.
This could have been caused by the IWE ( Integrated Wheel End ) solenoid ) TSB :
http://my.voyager.net/~sscully/file_tsb06_08_15.pdf
You can check the vacuum line with a vacuum pump and gauge tester, just to be sure, but considering it is grinding while in 4WD, I would say the IWE needs to be replaced on that side. Maybe change the IWE solenoid while you are doing the work ( it will be a rounding error on the total cost )
Feb 03, 2010 | 2006 Ford F-150
2000 Jeep Cherokee Gear Grinding & 4WD Whine sound
Give a try by change your transmission/filters and Transfer case oil.
Oct 27, 2009 | 2000 Jeep Cherokee
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
Minolta 2530 DL duplex paper handling
also check that you installed the duplex correctly, that the gears fit into right place. gears are making this sound
Feb 26, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Grinding noise
Is the noise comming from the right side of the copier? If so you need the upper fusing roller drive gear. It will break sooner then later.
Feb 08, 2008 | Sharp AL-1641CS Laser Digital Copier
Peg Perego John Deere Gator HPX Ride on Toy Logo
76 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
