Question about B&K Reference 7270 7-Channel Amplifier
No problem, just advice, have the 7270 reference II amp, what audio cables do you guys recommend (manufacturer/model) I am only going to do this once, want to do it right. Mating it up to a Integra DHC 40.2 7 channel AV receiver, all Klipsch reference speakers, including the RT-12d woofer. Thanks, great website, keep up the great assistance.
  • B&K Master
  • 5,391 Answers
With these it all depends on your budget. Some shops will let you try them out for the best results also. If you are in the UK have a word with the guys at Richer Sounds, they will sort you out. Elsewhere try and find a place that will let you try before you buy. After all it's all personal choice, your hearing isn't the same as me or anyone else's.
The link will take you too Richer if any good to you.
http://www.froogle.richersounds.com/products/hi-fi-separates/accessories/hifi-interconnects
Posted on May 25, 2011
How do I program the crock pot to cook a certain amount of time at one temperature and then lower the temperature and continue cooking
Without the make & model we can't give any meaningful advice on this.
You should either go to the manufacturer's web site to search for the manual or google make, model and the word "manual" or "instructions"
Jan 06, 2015 | Crock Pots & Slow Cookers
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
Is there a conversion kit for Jenn-Air Model No: 720-0061-LP to convert from LP to Natural Gas?
Matt, I am not aware of one. Nor, whether it's approved or not, by the manufacturer, Nexgril.
My best advice is to contact their Customer Support Dept @ 800-913-8999
Keep in mind, it you are able to convert it, the gill will no longer get as hot as it does with propane.
Propane burns hotter than Natural Gas in an outdoor environment.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Jul 28, 2011 | Grilling
I have a model 7800 amp and and have been using it with my pc for sometime. I now wish to use with a Phillips Chassis EL1-1u-aa model 37ff7321D/37 TV monitor and the male plugs from my amp do not seem to...
"7800" amp isn't a unique term. Who makes it? An amp with male plugs, really? Most audio devices and amps have female RCA inputs connected by male cables.
All that alphabet soup for the TV gets bupkus, too. YOURS is the only hit on Google.
Go to http://www.p4c.philips.com/files/ and drill down to find the manual for your TV and see what it recommends for audio connection to an amp. Be patient, the initial alpha directories are slow to load.
If the TV programming originates with a Cable Box, use IT as the audio source. TV -audio is usually minimalist.
Jun 26, 2011 | Boston Acoustics VR950 Main / Stereo...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Tv has no audio out jack
HI, use a scart adaptor to get phono audio out puts from your tv,be sure to use the scart which gives audio out this is the one with a box and arrows pointing in &out can be a little hard to see so if you have no sound try the other scart. Hope this helps.
CABLE GUY.
Jul 18, 2009 | Bose Cinemate Digital Home Theater System...
Sanyo DS25390 TV Problem
Check the cables is true that the cables has to be connect with some..device "White" and "Red" (OUT)>>> and (IN) on the "T.V"..On the T.V Audio check if is not on mute, or of still have problems yet..check the settings see about something about "Audio Options" but go to the manuals first.
Feb 12, 2009 | Sanyo Televison & Video
Repairing my Nokia 7270
the best if you have some skills soldering is to do it yourself. is very easy. if you need any help let me know
Aug 27, 2007 | Nokia 7270
B&K Reference 7270 7-Channel Amplifier Logo
81 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
