Question about EnGenius EAP-3660 802.11b/g Wireless Access Point
I have a linksys router with 2 EAP9550 APs. I can't configure the access points to work as repeaters. They work as assess points but I am having problems as repeaters. Any basic suggestions? Thanks Ted
  • 36 Answers
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Need to install on my hp laptop yes eap9550
You do not need and installation or a driver to connect to an access point. If you need a driver, it'll be the driver of your wireless lan card.
Feb 17, 2012 | EnGenius EAP9550 Wireless Access Point
I have a Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point but when i connet to the laptop to configure it does not detect the access point . the Act light does not blinks nor the acess point gets...
Try reseting the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 15, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
Good day, I want to connect three/four Cisco linksys wireless router wirelessly together in a home network such that: 1. Systems working with each AP can comunicate with those with other AP 2. all of...
Ok, what you really want to do is have one router as an access point and the others all set as repeaters.
You'll want to find some WAP54G for the access point/repeaters
The procedure, I cannot explain better than this article does:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4200
it has diagrams and the works on setting those routers into repeater mode.
Post a comment here if you have any issues with that configuration!
NOTE: your configuration should use 2-3 WAP54G with a WRT54G as your main router at the modem.
Feb 22, 2011 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
EnGenius EAP-3660 802.11b/g Wireless Access Point Logo
381 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
