Question about Garden
How do u get the handle of the chop saw to lift up
  • 436 Answers
Usually there will be a locking knob on the side of the blade handle. if you cant locate, send me model # and brand.
Thanks
Posted on May 20, 2011
Steps to operating the Ryobi chop saw.how do you unlock it
Push down on the handle, a spring load pin should move out. Mine is on the left side where it hinges. Lube it if it doesn't move easily.
Jul 16, 2017 | Ryobi Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
The safety pin on my riobi chop saw is jammed -- when I push down on the handle and try to pull the pin out it's just stuck
you can try using a WD-40 to lube it or I am thinking that you are not getting enough travel to release the pin. Is the head of the saw hitting on something not allowing full movement. Let me know
Feb 25, 2012 | Saws
Replace switch on chop saw
unplug tool, remove the top of the handle assembly, either take a picture or write yourself a wiring schematic before removing anything, I would suggest taking a photo so you know where the safety device goes and the wiring, loosen the screws and remove and replace the switch.
Oct 01, 2011 | Makita 10" Miter Saw LS1030N
Handle for chop saw
You did not place a make or model number here...
Here is a website that has many parts for many different tools...
http://www.ereplacementparts.com/
heatman101
Mar 15, 2011 | Hitachi Saws
Metal chop saw blows breaker
Is there anything else running while you are cutting? If not is the breaker 15 amp or 20 amp. If its 15 amp, I would change it to a 20 amp breaker. Make sure the wires are thick enough to handle the extra load. If this isn't the problem check the cord from the saw to the outlet.
Good luck!!
Jul 28, 2009 | Dewalt Chop Saw D28700
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
