Question about Brother Office Equipment & Supplies
Copier will not print dark enough even with new cartridge
  • 525 Answers
Your laser module is dirt, disassemble laser module and clean dirt with cloth and alcohol.
Posted on May 22, 2011
My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Sep 29, 2010 | Samsung ML 1610 Laser Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Even though both the color & b/w cartridge are new my print job is very light
You can try setting that darkness in your menu for set up printing. That will make it darker. If this just happened after changing the ink clean the jets before setting the darkness.
Dec 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
Lexmark 1270 don't print dark enough although the ink cartridges are full how can be the problem
near the platten ( paper roller) there is a lever to alter the pressure +, - increase towards the +
and see if that makes a difference
Jun 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
Not dark enough
If you use a refilled cartridge all print quality problems should go back to the supplier of the ink.
Lexmark does not now and never has authorized refilled cartridges on their products for this exact reason.
Lexmark cannot guarantee the quality of the ink.
Apr 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Not printing black dark enough, faded
Get a manual off the internet -- they are avalible for free for now as hp has stopped supporting these plotters. Then llokup the section on adjusting the ploter carraige head.
Techs adjust the head by turing the mentioned screw a little ie from 12 oclock to 1 oclock to the right test for print quality then adjust back or more .
hope that helps
Aug 02, 2008 | HP DesignJet 450c InkJet Printer
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
