Where is the socket for the data cable? - Computers & Internet
    Scholar:
  • 92 Answers
Depending on your motherboard, you most likely have one of two types of data cable sockets. The first being an IDE socket which looks like this: (note the wide ribbon data cable)
The other would be a SATA socket, and is the latest type of data cable you will find on recent mothboards, and it looks like this: (note the skinny cable)
I hope this helps you! Have a great day!
Mike
Posted on May 20, 2011
Hi my hp compaq d530 cmt doesn't work when i brache the cable of alimentation it signe with red !! help me please .
how did you clean by hand ?
did you move any wiring data or power leads
Test all leads power and data that attach from motherboard to your hard drive,IDE,SATA
make sure all of you your drives power and data leads have secure connections
make sure the CPU central processing unit has a dust free secure seating
make sure your computer ram modules have secure seatings with no dust in sockets
Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
How do I add a slave hard drive to a computer
Is it an ide (flat wide data cable & 4 cable power cable) hard drive? There will be jumper pins near the data cable socket to set one as master and the other as slave.
Jan 05, 2012 | Dell Computers & Internet
How to connect internet with data cable
Join the computer and router together with a cable, this cable is normally called a cat5 cable and should have come with the router kit, there should be four or five sockets at the back of the router depending on type any will do, obviously the larger sockets anyway the only other one is the telephone input which is smaller and the power adaptor input.
Feb 19, 2011 | Computers & Internet
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
I Have vertical lines on my laptop what is causing it and how can I get rid of it. Is it the screen itself or just the inverter. There are five lines and my laptop is a Compaq presairo x6050US.
The inverter simply takes the power from the DC power supply and converts it to high voltage AC for the backlight display. Vertical lines are from a loose or damaged data cable that usually connects on the left side, rear of the display or the lcd panel itself is failing and the lines are usually indicative of this type of failure. If you grap the screen on either side and "torque" it or twist it slightly and the lines go away or are diminished, then there maybe a problem at the socket on the back of the display, this is where the data cable attaches. Over time these sockets can get "wallawed" out and not make good contact. The only repair for this socket damage is lcd panel replacement. I doubt it is the cable, but there is always the chance.
Aug 11, 2010 | Compaq Computers & Internet
My Hp Pavilion 2000 has wavy display lines on opening laptop, but if lid jiggled backwards it is corrected. Plugged into spare monitor it's OK, also if started when lid open. Doesn't have the overheat...
You most likely are dealing with either a loose connection from the data cable to the lcd panel or the socket on the lcd panel itself is having issues. There are instances when the data cable will rub against the hinges and ground itself through the worn areas of the cable. The bezel on the screen needs to be removed and the cable inspected. Look for wear marks around the hinge area and then remove the screws on the side of the panel that attach to the hinge arms, this will allow access to the back of the panel to inspect the socket and cable connection.
Jul 09, 2010 | IBM ThinkPad T23 2647 Notebook
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Hard drive data cable was removed
The red side of an IDE cable lines up with pin 1 of the hard drive, closest to the power socket on the hard drive, and pin 1 of the motherboard.
Depending on your drive, Maxtor has videos of the installation process at their support site, available by clicking here
Apr 10, 2009 | Maxtor Hard Drive
Data cable input?!
iR400 requires a printer board fitted to it to make it network capable. The data cable goes in the socket at the rear-left of the machine.
Oct 08, 2007 | Canon imageRUNNER 400S Copier
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
