Question about Saeco Coffee Makers & Espresso Machines
When I fill my saeco expresso italiano 035DR with water, it leaks through filter until plugged in. Please help me. Dean
JohnnyBeans
  • 223 Answers
SOURCE: Saeco Italiano
http://cerinicoffee.com/Saeco_technical_documents.asp
Posted on Nov 28, 2007
SOURCE: Saeco Royal Exclusive expresso
I had the same problem. The solution is to replace the WAter Tank Gasket, which is in the machine, not in the tank.
Use a flat screwdriver to carefully remove (lift) the cover of the gasket. this is the round hole in the center where the Water Tank fits.
you can then remove the gasket. Ordering it online is ~ $5 plus the shipping.
Good Luck.
Posted on Feb 09, 2008
mirran
  • 515 Answers
SOURCE: My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Posted on Aug 23, 2008
EsWorld
  • 1618 Answers
SOURCE: water leaks out of the bottom of of our Saeco
There is a leak in the machine on the line from the pump to the brew valve that connects to the brew unit.
Posted on Nov 15, 2009
  • 18 Answers
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Posted on Feb 10, 2010
How do you stop the water leaking on the Incanto Model of Saeco Expresso maker?
Likely an issue with steaming valve,. They wear out every year with regular use. They can be fixed easily by service guy.
Nov 20, 2010 | Saeco Incanto Classic Espresso Machine
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Vienna leaks water from water tank
Sorry for the delay in response but I just read your complaint. I had similar water leakage issues and mistakenly replaced a bunch of stuff without stopping the leaks, until I discovered the real problem; the O ring seal that the water reservoir sits in located under the reservoir where it mates with the machine. Easy to replace and cheap. No leakage problems since I both replaced the O ring and started the routine of not taking off the water reservoir to fill it, but leaving it in place and filling it from a bottle. That technique does not any wear at all on the seal ring and so it won't leak in the future.
The item is called a "Saeco-water inlet valve gasket" , has a part number of NM05.006 and costs $7.50. I purchased it from Services Unlimited located at 650 N. Cannon Ave. WH-305, Lansdale PA 19446; phone 215-361-7000 Fax 215-361-7434, e mail granita@rcn.com but you can find it at any authorized dealer, I am sure. I ordered two and with shipping the cost came to $21.50.
You can request a fax with a parts diagram and listing, which I found most helpful in diagnosing issues and see where stuff goes..
Hope this helps you..
George W Conrad
Feb 18, 2009 | Saeco Vienna Espresso Machine
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
hello you say sometime water leak out normally when the water valve seal is defective it will always leak. look under the water tank you got 4 plastic guide moulded in the container make sure no guide broken or missing a little pease of plastic if you got a pease missing add whatever missing inthe hole like a shim check it out cheers
Jan 11, 2008 | Saeco Royal Exclusive 30153 Espresso...
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
