Question about Konica Minolta MAGICOLOR 4650EN 24 ppm 90,000 PAGES PER MONTH Laser Printer
Hello, the Displays says: Service Call 0F53 TE Sensor M Greetings
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Test kit is available to run drill without electronics.
Sep 17, 2012 | Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Lost casio operational manual
Is it any of these?
Casio 103ER operators manual
Casio 110CR and 150CR and PCR-250 service manual
Casio 110CR and 150CR user manual
Casio 116ER operators manual
Casio 120CR-B and 160CR-B user manual
Casio 120CR and 160CR service manual
Casio 120CR and 160CR users manual
Casio 120ER users and programming manual
Casio 130CR PCR-262 CE-160 service manual
Casio 130CR users manual
Casio 140CR PCR-272 service manual
Casio 140CR user manual
Casio 200CR and 240CR and PCR-360 and PCR-365 and PCR-465 service manual
Casio 200CR operators manual
Casio 204SR 208SR 7100SR 7200SR 7300SR user programming manual
Casio 210ER users and programming manual
Casio 230ER operation and programming complete manual
Casio 230ER technical troubleshooting guide manual
Casio 240CR operators manual
Casio 2122ER and 2124ER and 2128ER Operation and Programming manual
Casio 3904ER 3908ER 4912ER 4920ER 4930ER programming manual
Casio CE-200 and CE-250 and PCR-365A service manual
Casio CE-250 operators manual
Casio CE-280 operators manual
Casio CE-285 Operating and programming - SPANISH ONLY manual
Casio CE-285 operation and programming manual
Casio CE-300 service manual
Casio CE-310 service manual
Casio CE-310 users manual
Casio CE-2108 operators manual
Casio CE-2300 operators manual
Casio CE-2350 operators and programming manual
Casio CE-2350 service manual
Casio CE-2400 service manual
Casio CE-2400 users and programming manual
Casio CE-3700 and CE-3750 service manual
Casio CE-3700 operators and programming manual
Casio CE-4000 and CE-4050 operators and programming manual
Casio CE-4000 and CE-4050 service manual
Casio CE-4700 operation manual
Casio CE-6000 service manual
Casio CE-6000 users and programming manual
Casio CE-6100 service manual
Casio CE-6100 users manual
Casio CE-6800 service manual
Casio CE-7000 service manual
Casio CE-7000 TK-6000 TK-6500 TK-7000 TK-7500 TK-T500 LCD-KIT2 service manual
Casio CE-7000 users manual
Casio CE-T100 users and programming manual
Casio CE-T300 service manual
Casio CE-T300 users manual
Casio CV10 V2.01 software users manual
Casio DP730S printer technical manual
Casio FE-810 service manual
Casio FE-3000 service manual
Casio FE-4000 service manual
Casio FE-5000G dealer programming manual
Casio FE-5000G service manual
Casio FE-5000G user manual
Casio HHS-15 service manual
Casio IO-PB-11 option board service manual
Casio IO-PB-12 option board service manual
Casio M-190G printer service manual
Casio M-U420 technical manual
Casio MD-910 printer technical manual
Casio MP-2000 service manual
Casio PCR-204 operators and programming manual
Casio PCR-208 operators and programming manual
Casio PCR-210 operators and programming manual
Casio PCR-250 and 150CR users and programming manual
Casio PCR-255 and PCR-260 service manual
Casio PCR-255 and PCR-260 users and programming manual
Casio PCR-255P and PCR-275 service manual
Casio PCR-255P users manual
Casio PCR-260B users and programming manual
Casio PCR-262 and CE160 users and programming manual
Casio PCR-265P service manual
Casio PCR-265P users manual
Casio PCR-272 operation and programming manual
Casio PCR-275 users manual
Casio PCR-330 operators and programming manual
Casio PCR-355 operators and programming manual
Casio PCR-360 operators and programming manual
Casio PCR-365 operators programming manual
Casio PCR-365A operators manual
Casio PCR-365P service manual
Casio PCR-408 operators and programming manual
Casio PCR-450 Operation and programming SPANISH ONLY manual
Casio PCR-450 operators and programming manual
Casio PCR-460 operators and programming manual
Casio PCR-1000 service manual
Casio PCR-1000 users and programming manual
Casio PCR-T48S T470 T480 T470L T480L T220S T2100 T2200 T2100L T2200L service manual
Casio PCR-T265 and PCR-T275 and TE-M80 service manual
Casio PCR-T265 users manual
Casio PCR-T275 users manual
Casio PCR-T280 operating and programming manual
Casio PCR-T465 and CE-T100 service manual
Casio PCR-T465 user and programming SPANISH ONLY manual
Casio PCR-T465 users and programming manual
Casio PCR-T470 users and programming manual
Casio PCR-T2000 users and programming manual
Casio PCR-T2000 version 3 service manual
Casio PCR-T2000 version 4 service manual
Casio PCR-T2100 user and programming FRENCH ONLY manual
Casio PCR-T2100 users and programming manual
Casio QT-2000 installation and down recovery manual
Casio QT-2000 programming manual
Casio QT-2000 reference manual
Casio QT-2000 service manual
Casio QT-2000 user manual
Casio QT-2100 installation and down recovery manual
Casio QT-2100 programming manual
Casio QT-2100 reference manual
Casio QT-2100 service manual
Casio QT-6000 installation and down recovery manual
Casio QT-6000 programming manual
Casio QT-6000 QT-6100 IPL4.12 and QT-6600 IPL1.12 Hospitality guide manual
Casio QT-6000 reference manual
Casio QT-6000 service manual
Casio QT-6000 users manual
Casio QT-6100 installation and down recovery manual
Casio QT-6100 programming manual
Casio QT-6100 reference manual
Casio QT-6100 Service manual
Casio QT-6600 Installation and down recovery manual
Casio QT-6600 IPL V1.20 features manual
Casio QT-6600 Programming manual
Casio QT-6600 Reference manual
Casio QT-6600 Service manual
Casio QT-7000 and QT-7100 reference manual
Casio QT-7000 and QT-7100 service manual
Casio QT-7000B and QT-7100B service manual
Casio QT-7300 service manual
Casio QT-7300 users manual
Casio QT-8000 reference manual
Casio QT-8000 service manual
Casio QT-8000F QT-8500F user programming manual
Casio RAC TOOL for SE Series ECRs user manual
Casio SA-3000 service manual
Casio SA-5000 and SA-5100 service manual
Casio SE-C300 SE-C2000 and SE-S300 SE-S2000 dealers manual
Casio SE-C300 users and programming manual
Casio SE-C2000 users and programming manual
Casio SE-S10 PCR-T280 PCR-T280L PCR-T290L service manual
Casio SE-S10 user manual
Casio SE-S300 SE-S2000 SE-C300 SE-C2000 TE-900 TE-1500 TK-950 TK-1550 service manual
Casio SE-S300 users and programming manual
Casio SE-S2000 users and programming manual
Casio SE-S6000 SE-C6000 dealer CA Ver manual
Casio SE-S6000 SE-C6000 service manual
Casio SE-S6000 SE-C6000 user manual
Casio Sigma 61ER 62ER 63ER operators manual
Casio SP-1300 service manual
Casio SP-1300 slip printer technical manual
Casio Superboard-II installation manual
Casio TE-100 service manual
Casio TE-100 users and programming manual
Casio TE-1500 user manual
Casio TE-2000 service manual
Casio TE-2000 service US-DLR version manual
Casio TE-2000 service version 3 manual
Casio TE-2000 users and programming manual
Casio TE-2200 and TE-2400 dealers manual
Casio TE-2200 and TE-2400 service manual
Casio TE-2200 users manual
Casio TE-2200 users EU ver manual
Casio TE-2400 users manual
Casio TE-3000S and TE-4000F and TE-4500F dealers manual
Casio TE-3000S and TE-4000F and TE-4500F service manual
Casio TE-3000S TE-4000F TE-4500F S-PLU stock control software reference manual
Casio TE-3000S users manual
Casio TE-4000 superboard installation manual
Casio TE-4000F and TE-4500F users manual
Casio TE-7000S and TE-8000F and TE-8500F installation and down recover manual
Casio TE-7000S and TE-8000F and TE-8500F programming manual
Casio TE-7000S and TE-8000F and TE-8500F reference manual
Casio TE-7000S and TE-8000F and TE-8500F service version 2 manual
Casio TE-7000S and TE-8000F service manual
Casio TE-7000S users manual
Casio TE-8000F and TE-8500F users manual
Casio TE-8000F TE-8500F user SPANISH manual
Casio TE-M80 users and programming manual
Casio TK-710 operators manual
Casio TK-800 service manual
Casio TK-800 users and programming manual
Casio TK-810 service manual
Casio TK-810 users and programming manual
Casio TK-950 user programming manual
Casio TK-1100 user programming manual
Casio TK-1200 programming manual
Casio TK-1300 and CE-4200 and CE-4250 programming manual
Casio TK-1550 user programming manual
Casio TK-2100 Programming manual
Casio TK-2200 user and programming manual
Casio TK-2300 and TK-2700 and CE-4700 programming manual
Casio TK-2300 and TK-2700 users manual
Casio TK-3200 Dealer manual
Casio TK-3200 service manual
Casio TK-3200 User manual
Casio TK-4200 and TK-4300 operators manual
Casio TK-5100 users manual
Casio TK-6000 and 6500 users manual
Casio TK-6000 service manual
Casio TK-6000 TK-6500 TK-7000 TK-7500 TK-T500 CE-6000 etc dealer manual
Casio TK-6000 TK-6500 TK-7000 TK-7500 TK-T500 CE-6000 etc troubleshoot manual
Casio TK-6500 service manual
Casio TK-6500UK service manual
Casio TK-7000 and TK-7500 users manual
Casio TK-7000 service manual
Casio TK-7000 service taiwan version manual
Casio TK-7500 service manual
Casio TK-T200 service manual
Casio TK-T200 service version 1 manual
Casio TK-T200 users and programming manual
Casio TK-T500 service manual
Casio TK-T500 users manual
They can be found here:
the-checkout-tech.com
Oct 08, 2011 | Casio Parts Cash Register PC Desktop
Just bought an Canon 8030 series, when we turned it on te first time (install, testprint etc) the colors where very light. We bought new toner en istalled them. When turned on the printer gave an 070-0000...
these is error for ITB ( transfer ) sensor. It pops up, if there is disconnected itb sensor, or on installation of machine, if all protective covers arent pulled out.
For concrete answer I can only gave you the service manual. Its hard to tell without seeing the machine.
emma.servis@gmail.com
Hope that helps!
Apr 27, 2011 | Office Equipment & Supplies
I have just baught a second hand casio TE8500f cash register and every time i turn it on it displays init 1.flag clear 2.init2 and every button i press it then displays operator mistake
Highlight "flag clear" and press YES button. If it still does not work, you have a flat or (usually) faulty memory battery and it will need to be RAM cleared then re-programmed.
If anyone needs more informaton on the Casio TE-8000f or TE-8500f, the manuals are here:
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_programming_manual.html
Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_service_version_2_manual.html
Feb 11, 2011 | Casio Parts Cash Register PC Desktop
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg washer wm2496hsm displays a "te"error what is this
The water temp. thermistor is @ fault or the main computer.
Service will be needed.
Jan 20, 2010 | LG WM2496H Front Load
Konica Minolta MAGICOLOR 4650EN 24 ppm   90,000 PAGES PER MONTH Laser Printer Logo
282 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
