Question about Kenmore Dishwashers
Kenmore model 665.17032402 type 575-0: will not fill with water. float does appear to move freely. machine will work if it is filled with water manually.
  • 641 Answers
SOURCE: Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Posted on Jun 08, 2006
reg501
  • 413 Answers
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
SOURCE: I need to reset the
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Posted on Sep 02, 2008
SOURCE: Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Posted on Dec 13, 2008
SOURCE: GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Posted on Dec 30, 2008
Dishwasher runs but no water comes in the dishwasher. Checked water supply, good up to begining of solnoid, but water doesnt go through it. Model DU810SWPQO WHIRLPOOL 2004
Heres what to check
FLOAT IN TUB...check it for sometime stuck under it, or it stem under float is gummed up
FLOAT SWITCH....if float is down and moves freely check for continuty on float switch
WATER VALVE ...check for 120 volts ac into wires on valve solonoid when supposed to be filling,
it's supposed to fill and beginning of cycle
Gene
Aug 14, 2011 | Dishwashers
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
On my SAECO Comfort + machine, the ''Fill Water tank'' message does not go off even aftre the tank is filled.
make sure the magnet inside the water tank can move freely or float if it is then thr sensor inside is faulty
Nov 28, 2009 | Saeco Magic Comfort Plus Espresso Machine
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Hi my Zanussi DI 720 dishwasher is not filling up with water i have checked the water supply which appears to be fine. Can anyone help.
hi
If a dishwasher runs but doesn't fill, either something is wrong with its water supply system or it is draining water too soon.
1) First make sure the water is turned on. Check the hot-water supply stop valve, normally located under the sink. Open it all the way by turning it counterclockwise. If there is no reason this would have been turned off since the last time the dishwasher worked, go on to the next step.
2) Turn off the power to the dishwasher.
3) When the dishwasher is cool, look for the float inside the dishwasher; this is usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring-loaded).
Lift out the float mechanism, and clean around the float tube. Many floats must be disconnected from below; to do this you'll have to remove the lower access panel. Rinse off the float, replace it in the tube, and make sure it moves up and down freely.
4) If you're experienced with minor repair work, shut off the hot-water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel; disassemble the valve to reveal the screen; clean debris from the screen; and reassemble. If the screen doesn't appear to be blocked, call a repairperson
Hope this helps
Nov 08, 2008 | Zanussi Dishwashers
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Dishwashers Logo
59 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
