Question about LeapFrog LeapSter L-Max Console
The touch screen no longer works on my grandsons' 5-month old leapster. Does the warranty cover that?
  • 661 Answers
Likely, yes. call leapfrog, and ask. However, most warranties do not cover abuse or accidents. If your grandson did something or dropped it, the warranty will not cover that.
Posted on May 20, 2011
Touch screen not working
I had the same problem with my daughter's LEAPSTER 2 handset - it was not responding to the stylus. Hopefully the following solves your problem.http://leapfrog.custhelp.com/app/answers/detail/a_id/1736
Feb 09, 2012 | Leapster 2
I can't calibrate the leapster.I can't get pass enter a name
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
If you have questions please let me know.Thanks for using Fixya
Aug 03, 2011 | LeapFrog Leapster 2 Learning System
We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    The touch screen on my Daughters Leapster 2 has stopped working. What can I do about it. The Leapster is 16 months old
    Hello
    You might want to call this number call 1-800-701-5327. to get technical support for your leapster.
    Thank you
    May 02, 2010 | LeapFrog Leapster 2 Learning System
    My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
    Answer
    I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
    If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
    1) Ensure that a cartridge is not inserted
    2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
    3) When the LEAPSTER menu screen appears, press the A button
    4) Touch each of the crosshairs that appear with the stylus
    5) Restart unit
    Jan 30, 2010 | LeapFrog Leapster Learning Game System
    TOUCH SCREEN IS NOT WORKING
    We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
    Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
    Oct 24, 2009 | LeapFrog Leapster 2 Learning System
    Leapfrog Leapster touch screen
    Press the ? button and hold it while turning unit on.
    Press the "a" button to select touch calibration
    Press each + with the stylus
    Restart machine
    Apr 10, 2009 | LeapFrog Leapster 2 Learning System
    Touch screen does not work
    2) Hold down the Hint button while turning the unit on
    5) Restart unit
    Mar 22, 2009 | Leapster Learning System
    Leapster with broken pen
    My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
    I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
    Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
    LeapFrog LeapSter L-Max Console Logo
    157 people viewed this question
    Top LeapFrog Video Game Consoles & Games Experts
    Ted Maxwell
    Andrew Taylor
    Andrew Taylor
    Morgan T Bradshaw
    Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
