Question about Toshiba CF27H50 TV
Toshiba model CF27H50 made a slight popping sound when turned on. The TV screen images are mostly green; no red, blue, yellow, etc. colors are prevalent. This the first time this has occurred. I have only tried a factory reset, yet the problem persists. What is/are the cause(s) of this problem? What part(s) will I need to resolve this issue? Any assistance provided would be appreciated, and thanks in advance.
  • Toshiba Master
  • 6,771 Answers
From the description you have provided it is the picture tube, the popping sound has come from the guns and created a grid short in the picture tube itself knocking out one or two primary colors. This can not be repaired short of changing the tube which would not be cost effective, the money would be better spent on a new set.
Posted on May 20, 2011
Testimonial: "Bravo!"
  • C TATE May 20, 2011
    Thanks, for your speedy reply Cunninghame. A new purchase is something that I have dreaded. Yet, I have had reliable service from this unit since its 10/1998 purchase. Well,... it's time to research its replacement (Wow, a 21st century TV!). Again, many thanks.
  • John Cunningham May 20, 2011
    Glad to be of service, John
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas?...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 01, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double Image Red and Green
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Back screen lights are out of sync
This projection TV is made up of 3 projectors R G and B (Red,Green,Blue) These colors mix to create the other colors all you have to do is both convergences
Nov 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
