Question about Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power
I am looking for dynamic ds100 controller for mobility scooter voltage input 24 volt current autput 100amp model number ds100ab serial number 96c23895
5 Suggested Answers
  • 11800 Answers
SOURCE: Have Shoprider Sovereign 4 Scooter.
The batteries are weak - either they are worn out or they are defective. They will have to be replaced.
Posted on Oct 23, 2010
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: i have power in to the control panel but no output
The Dynamic DS100 is not a sealed unit but is usually a replacement part. Unfortunately there are very few people in the UK that actually repair them. If you would like to open up the box to have a look at it yourself, the procedure is as follows:
Remove the 4 visable screws from the bottom of the box
Remove the smaller of the blue rectangular stickers from the bottom of the box
Remove the screw that was hidden by the sticker
Remove the 4 screws from the front of the box (where the plugs fit in) and pull away blue plastic part
Lift off the bottom metal cover
Remove the 3 screws that hold the lower PCB in place
Gently lift the lower PCB upwards to reveal the upper PCB
Remove the 3 screws from the middle of the upper PCB
Lift upper PCB out to access the top of the board
Hope this has been of some help to you.
Good Luck!
Posted on Apr 07, 2010
gewiz
  • 1263 Answers
SOURCE: my mobility scooter ('rascal' i
hi, the six flashes indicate a speed pot issue, the pot is not in centre position when you turn the scooter on, it a case of looking at the cross thread on the bottom of the stem and making sure that it is centre to you when sitting on the scooter or use a multimeter to get a 2.5 to 2.7K ohms centre reading.
Regards GewizRepairs
Posted on Jul 26, 2011
Testimonial: "the speed pot had got a little moisture in there i suspect and the vibration from the corrugations hadn't helped either. I pulled it apart and cleaned"
Has anyone a circuit diagram and possibly information about the transformer output voltages for a Pihsiang mobility charger model MB-24/3 battery charger?
Hi again i have no data on Ac voltage output AT A GUESS I WOULD THINK IT WOULD B APROX 35 TO 38 VOLTS one thing i did find u can still buy them at MONSTER SCOOTER PARTS ITEM NoCO4-1179 PRICE $183-99 PHONE NUMBER 800-798_0325 GOOD LUCK. input : 100-120 VAC, 50/60Hz 1.5 AMP. U CAN BUY NEW ONE'S ON E/BAY,,..hi output is 24 volts 3.0 amps hope this helps..........
Dec 11, 2015 | Health & Beauty
How to wire battery pack
hi , what scooter is this for ?
for 24 volt systems( a larger number of mobility scooters ) ... remember lithium powered scooters can be different including the the charge voltage of 29 volt...
okay you wire run the batteries in serial configuration...
Apr 16, 2015 | Health & Beauty
How do I check the battery charger to see if it is functioning properly
Some chargers need to be connected to the batteries before they turn on the charge current. With the charger connected and switched on, check the voltage across the batteries and should be about 26 volts for a 24 volt system. And you can use an amp clamp meter for current flow.
WARNING
DO NOT SHORT PINS TOGETHER
Mar 26, 2015 | Health & Beauty
hi, What do you want to change ? ,
Regards
Rob
www.gewizrepairs.co.uk
Jul 19, 2014 | Health & Beauty
My mobility scooter ('rascal' i think) has a dynamic ds100 control unit. i took it down south on a traylor and it got mildly wet and a little shaken on the way down. By the time we arrived-it...
May 13, 2011 | Power Health Scooter Wheelchair Programmer...
HELLO, I AM WONDERING WHERE I CAN LOCATE A MANUAL FOR A ( SHOPRIDER 3 WHEELER, THIS MODEL HAS THE LIGHT PACKAGE, COIL OVER SHOCK SYSTEM. AND I WOULD LIKE TO HAVE A MANUAL. AND KNOW WHERE TO FIND...
All Scooters are 2ea 12 volt batteries in series = 24 volts dc
Serial numbers for a shoprider are on the seat post or body frame, some scooters over the years have lost the sticker and you won't be able to find one.
Here is what will help you get a manual.
Call Shoprider 1-310-328-8866 or 1-888-896-8866
Good Luck
mimobility wizard_s.gif Wiz
May 02, 2011 | Health & Beauty
I have a silver leader 4 mobility scooter with a dynamic ds 100 unit under the rear end the status light is flashing 7 times which from what i have been able to find out is the wig wag potentiometre have...
hi,
ok so 7 flashes is a speed pot related error, you need to make sure that the speed pot is in the central position , look under the stem and you should see a cross head , now that should be straight not at slight angle, without you touching the throttle lever , if you have a meter disconnect the pot and take a resistance reading, it should show about 2.5K - using the centre tap , if it is a 5K pot fitted , in fact for that controller it should be a 5K pot , please check the terminal connections on the controller, good fitting and clean.
Take leave feedback.
Regards GeWiz.
Feb 11, 2011 | Power Health Scooter Wheelchair Programmer...
After about 1 km on any power setting the scooter slows down on its own then surges up to power again. it gets a small back emf and this seems to help but is persistent some tiime down to 2 km/h checked...
Based on your description of the symptoms, I would load test the batteries, check the throttle potentiometer, speed potentiometer , motor brushes and motor brake. I cannot determine your specific model based on the way the problem was posted, so it is difficult to give specific advice.
Weak or old batteries will give the performance you are describing. Fully charge the batteries and load test them to determine their strength. Batteries more than 1.5 years old are suspect. Without a load tester you can do a load test by connecting your digital voltmeter to the batteries and run the scooter under load (driving it with weight on it). If the voltage drops more than 1.5 volts from a starting voltage of between 24 and 27 volts the batteries are weak.
Generally speaking, you can do a resistance check of the potentiometers throughout the range using a digital voltmeter. The specification for the potentiometers is stamped on the case. If there are dead spots when you turn the potentiometer based on a drop at the voltmeter then your problem is with one or both of the potentiometers. I usually replace both since they are usually wired in series.
Worn or bad brushes, worn motor armature, accumulation of brush dust, or a dragging brake can also cause the symptoms you describe. Pull and inspect the motor brushes for wear or burning. Blow out the motor with compressed air with the brushes removed and inspect the brake for discoloration or dragging. Do a resistance check on the brake. It should read between 30 to 60 ohms. The motor coil should read between 0 to 1.6 ohms.
Hope this helps.
Dec 30, 2010 | Power Health Scooter Wheelchair Programmer...
I have power in to the control panel but no output is the ds100 a sealed unit that has to be replaced or is it repairable?? Thanks Alan It is a DYNAMIC DS100 on a Kensington Freerider mobility scooter
Good Luck!
Mar 25, 2010 | Health & Beauty
When moving foreward or in reverse after letting off of control scooter keeps moving about 1 foot. I have run into doors and other objects.
You don't mention what sort of scooter you have, but 90% of them have the same types of controllers made by two different companies; PG Drives technology and Dynamic Controls.
These, as well as most of the others, are programmable to adjust acceleration, maximum speed, and braking. You have to have a programmer in order to adjust these factors, which means you need to either buy one that works on your model controller, or find a service tech that has the programmer. Call the manufacturer of your scooter with the make and model number handy, as well as the serial number, if you can locate it on the scooter, and ask to speak with a technical rep. He'll point you in the right direction.
Jul 09, 2009 | Pride Value Line Revo Scooter 3 Wheel
Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power Logo
271 people viewed this question
Top Power Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Power Health Health and Beauty Expert? Answer questions, earn points and help others
