I have a lamona 1200 rpm washing machine, i have lost the manual and need a new one as it is not finishing the cycle and making more noise than before
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
ginko
  • 19396 Answers
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
My Kenmore is making a short buzzing noise then stops.
More information is needed to try and diagnose any specific problem. But, is the machine finishing the wash cycle, properly? Some appliances sound an alarm/notification shortly before they finish their 'cycle.' Good luck.
Dec 03, 2014 | Kenmore Washing Machines
Lamona hja 8553
Unfortunately Lamonoa doesnt make washing machines. Its a wood fitting company that uses various machines. They reccomend this manual
http://pdfsb.net/readonline/5a6c4244656739355758422b436e6c6a55554d3d
for the 8553.
You have to read online..through the pdf
Mar 20, 2014 | Washing Machines
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
672 people viewed this question
Top Washing Machines Experts
