Hi - I cannot get a signal to my monitor - I'm using a Dell XPS desktop and experienced wavy lines across my screen for a while. Then i could not get a signal at all on my montior. I went and bought a new monitor but now I get no signal at all to it Can you help me?
  • 3,051 Answers
Do u have a spare monitor you can try to see if that one works if that doesnot work than you probably have a video card going out
Posted on Aug 14, 2008
My monitor has a thin black line across it. can it be fixed?
Try to find online stuck pixel fixers and if that doesn't work then your screen is probably shot.
Sep 13, 2014 | Dell desktop and monitor -Inspiron...
Hi, I have a dell xps product red, was working well, shut down last evening and now when i press the power on there is no noise of any sort and the only light which illuminates is the monitor screen light....
Check that the power cord is plugged into the wall and the computer. If you're using a power strip, double check that it is plugged into the wall, and turned on as well.
If you still get no response from the machine, open the case and look for spinning fans or lights from the motherboard when you press the power button. Generally, a bad power supply is going to still allow your power button to blink amber warning, as a pass through from the power cord.
Nov 14, 2012 | Dell XPS One Red Desktop Computer
Red and yellow line across the screen.
From the description the LCD screen will need to be replaced, first! hook a spare monitor to the video output on the back, if picture okay! the problem is the above mentioned, but if both screens show the same symptom it is the video graphics card.
Apr 19, 2012 | Dell XPS M1530 laptop, Crimson RED, 15.4"...
My m1330 shows only desktop picture and then go blank when turned on
faulty screen / inverter or grahics card on motherboard
use external monitor to check signal from laptop to monitor,
if signal is ok. then screen needs replacing
if no signal then graphics card problem
Dec 31, 2010 | Dell XPS M1330 Notebook
Yes my dell xps 410 is barely used but the problem im having is when i turn it on that the picture is snowy u know like when the cable goes out or when you cant get no reception i cant get nothing on...
That's a very strange problem. The typical problem with a monitor is that there is no signal, and so the screen goes into a "screen saver" mode. It sounds like it is behaving as if it were a TV. Does your computer have a TV tuner on it? Some models have this option. I'm just wondering if you might have accidentally changed something. Was it working fine up until just now?
Nov 07, 2010 | Dell XPS 410 PC Desktop
Gateway VX 920 Diamatron monitor has wavy lines at bottom
Since this is a CRT (Cathode Ray Tube) It is no longer cost effective to repair them. Your Tube Driver circuit (internal non-serviceable parts) is starting to fail.
Apr 05, 2010 | Computers & Internet
Tiny ------------- all over screen,Dell is no help.
your monitor has came in contact with some magnetic material remove all the things containing magnetsfrom around it and leave monitor unplugged for 1 day and then start it will work fine
pls rate my solution
Feb 19, 2009 | Dell XPS 410 PC Desktop
XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
Jumpy and wavy screen
without details on the hardware, this is just a guess, but you might try an updated video driver
Jan 19, 2009 | Dell Dimension XPS PC Desktop
Monitor will not start
So, when the monitor is on, connected to the wall (not to the computer), there's absolutely no signal? no message on the screen? no colors moving? Have you tried with another power cable? You can try this test. Use the computer's cable to test if the problem is the monitor's cable.
Nov 19, 2008 | Dell XPS™ 600 PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
