Question about Casio Wave Ceptor Atomic Silver Tone with Analog Blue Dial and Metal Band. : WVQ201HDA 2AV Watch for Men
I need to set the correct time on my wach - Casio Wave Ceptor Atomic Silver Tone with Analog Blue Dial and Metal Band. : WVQ201HDA 2AV Watch for Men
I have a timex solar and the indiglo stoped and the wach is losing time the bat. Is new
your Timex watch is solar which means it gets power from light, you have to expose it on direct light to recharge your battery but if it not works you had to bring it to timex service center. i hope this will help you.
Aug 12, 2011 | Timex Watches
I have a g shock 4762 g011ad wach but i lost the manual and i can`t update time and date in it.
Browse thrugh my tips and tricks and there you will find link for all Casio watch manuals.
Feb 25, 2011 | Watches
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
Reset itslelf. WIll not display correct time, day, or year
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
Nick
May 29, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do i adjust date and time
the knob at the side....
  • First pull which will change the date.
  • Second pull which will set the time.
thank you
Apr 06, 2009 | Orient Automatic Sapphire World Timer...
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Rolex wach booklet
Try http://chronograph.homestead.com
Dec 19, 2007 | Rolex Daytona 116520 Wrist Watch
Watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Oct 31, 2006 | Nautica N07518L Wrist Watch
Casio Wave Ceptor Atomic Silver Tone with Analog Blue Dial and Metal Band. : WVQ201HDA 2AV Watch for Men Logo
79 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
