Question about MSI 661FM-3 (661FM3L) Motherboard
Motherboard I was getting power but it seemed like it shorted out or something and I kept trying to reboot it but it would keep on hitting the dvd players and not boot, now it will not power up at all. What's up?
Can you check oncemore and check the processor once
Posted on Aug 15, 2008
I have a Acer Aspire 6920. It keeps rebooting even while reinstalling Windows 7 or Vista ,Memory was change and hard drive same problem.
DEAR SIR,
WHEN MEMORY & HDD IS OK, PLS GET YOUR MOTHERBOARD CHECKED BY TECHNICIAN ,, SOMETHING IS ERIOSULY WRONG WITH CPU SUS SYSTEMS.. , GRAPHIC, MEMORY , STORAGE ALL SYSTEM SEEMS TO BE OK ..
Feb 10, 2011 | Computers & Internet
I have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Feb 09, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Compaq Presario F700 reboots every 2 seconds.
I just wrote up a big explanation and posted it and now I don't see it anywhere (discouraging). So here's my short version. I had this reboot every 2 sec problem on my Presario F700 and finally gave it up for dead. I used the site http://www.insidemylaptop.com/disassemble-compaq-presario-f700-notebook/ and popped off the top cover (where the power button is) and took the HP Sticker off the power button and it's worked fine so far. I tried all the other things everyone suggested (the remove the hard drive, etc.) and those didn't work. So far...it's working good. I hope it works for you!
Sep 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
Rebooting computer wen entering cd even if data cable is unplugge
I can barely understand what you are saying. But if I have it right the system reboots by itself when a CD is inserted...
NEVER remove the data cable while the power is on. [you only get away with this once or twice and then you WILL break something.]
Do not connect a HDD to the same cable as your CD drive. The CD/DVD drive should be on its own cable witt nothing else attached [80pin conductor]. The HDD should be on its own cable. It has a different cable with different configuration and is NOT suitable for your DVD/CD...
Mar 26, 2009 | ASUS P5LD2-VM Motherboard
Computer Does not Boot correctly, Monitor is Black.
Very interesting...Might try the following...
- Video. Yes, almost garuntee that it is either the video card/onboard or the cable. Look at the cable and cable connectors and see if one of the pins has been shoved in. This is common. Often, one will replace the cable and still have the problem because a pin has been shoved in on the mother board.
- Power. Remove everything from your computer except the keyboard and the monitor (yes, even the mouse) to eliminate any power drain issues. If you can, remove the DVD drive (unplug power and data bus cable).
- BIOS. One beep is good. You should be able to get into the BIOS setup no mater what other problems you are having. The BIOS uses a generic text, video and keyboard driver. If you aren't able to see ANYTHING after the beep then it is definately the route from the motherboard through the video card or onboard video, through the cable to the screen. You seem to be going through the right steps to debug but just haven't found it yet because it is something that you have dismissed as working...like the pins on the video connector. Go through your path again, this time look at anything that you have assumed that was working and suspect it as the issue.
Jan 08, 2009 | Computers & Internet
Reboot windows XP
This problem might occur because "USB 4" might be a bootable device. To prevent "USB 4" from booting, Enter your BIOS and go to the 'boot priority' section.
Set it in this order: 1. CD/DVD Drive 2. Removable Devices 3. HDD.
IF that does not work, place HDD as the second priority and Removable Devices as the third.
To enter your bios, Hit F2, F12, or Delete repeatedly. I am not sure which key it is for your motherboard, but hitting all those buttons should do the trick.
Dec 29, 2008 | Dell Dimension 4600 PC Desktop
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Sep 27, 2008 | IBM Aptiva E 240 (2158240) PC Desktop
Gateway desktop 506gr power issue narrowed down?
That was pretty unclear.  Is there a kind of burning symptom that suggests a short to you?  It seems to me that what happened is that either there was a power outage and your system thus shut down...all you'd have to to would be hit the computer's power button to turn it back on...or a fan somewhere died and therefore the system won't power up until you replace or repair that.  At least get a vacuum in there and brush out the dust so you can work.
What happened when you got a simplified system that 'worked'?  Was the power supply's fan spinning, at least?  What's the green light on, anyhow?
Jul 31, 2008 | Gateway 506GR PC Desktop
Chaintech Motherboard NO SCREEN
Unplug the power. Then start with only the items you need to boot. Remove any cards that might be causing an issue, if you can't simply find the culprit of your boot lock issue. This sounds like a card or some RAM or something isn't quite plugged in. If your power supply still gives power to the system check to see if the fan on the power supply died. This could mean you need a new power supply if the old one overheated and cooked itself.
Sometimes you will get a card that is half plugged in and it will cause a short and the system will not fully power to avoid ruining the motherboard completely. After re-seating all the cards, try to boot it again. Check ALL connections and look for any USB connection that might be stopping the system from booting as well.
If you have a different video card you may want to try it next if you still can't get video.
Hope that helped out...
Dec 12, 2007 | Intel D101GGC Motherboard
MSI 661FM-3 (661FM3L) Motherboard Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
