Question about Kenmore Ovens
My kenmore oven doesn't work. There was a poof and cloud of smoke from the back of the stove when I turned it on and it now longer works. The stove works fine. The clock doesn't light up anymore either.
    Scholar:
  • 52 Answers
ISOLATE MAINS POWER BEFORE OPENING PANELS
It sounds like you have acomponent blow, (stating the ob), what I would recommend is a visual inspection. remove panel on rear, have a good look at wiring and conponent that are visable. If no sign of black short on terminals it may be an element. The fault could be in the panel circuit but that would not produce enough smoke, a fan motor can an element and a electric switch, they use the two terminal type mounted usually on the chassis, if this appears burnt out replace with the same temp type. To go further you will need electrical knowledge, and a test meter. Let me know if you require further assistance.
John
Posted on May 20, 2011
My oven doesn't turn on but the stove top works fine. It just blinks e0 03
I would check the heating element assuming this is an electric.
Jan 28, 2013 | Ovens
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Power was disrupted and stove needs resetting
Try turning the power off to the oven totally and leaving it for a few mins, then turn it back on. If this doesn't work you may have to have a new clock/timer. espares used to have them. If you don't see it listed, send in a request.
Jul 29, 2011 | Stoves 720EF Electric Double Oven
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
