Question about Thermador C301U Electric Single Oven
Thermador 30" wall oven.
    Scholar:
  • 195 Answers
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
Posted on Dec 02, 2011
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
F-24 goes on after oven on, and oven starts to beep
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Feb 28, 2011 | Thermador C302U Electric Double Oven
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
Sep 27, 2010 | Thermador SC302T Electric Double Oven
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Thermador C301U Electric Single Oven Logo
301 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
