The fuser can be replaced by opening the back cover and removing 2 screws. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
http://www.precisionroller.com/fuser-assemblies---units-for-brother-mfc9840cdw/products.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "Thank you!!"
BTW... no hazards involved.
Did this not help you? If you need further help, let me know.....
i can't enlarge the pictures to see the diagram.
send me your email, I will send the PDF
you are welcome....Please re-visit the rating. Thanks
Thank you... u r welcome...
can you also send to [email protected] the pdf. thanks.
Can you please also send this to [email protected]. Thanks!
This usually works.
MFC- 9440, 9840cdw Print Unable 32
Usually caused by a sticking density sensor solenoid and can easily be repaired.
Remove the rear cover
Remove the fuser
Remove the Hi Voltage PCB
Check the angled density sensor window for sticking. When you move it, it should spring right back. If it hesitates at all, repair the solenoid.
Remove the old foam and replace it with adhesive labels.
Reassemble machine and test.
