Question about Mitsubishi WS-55807 TV
Picture blinks then gets lighter then darker
Most visible when no lights are on - blinks brighter then blinks darker
  • 927 Answers
Good Day, freden899;
Your 2000 unit may be experiencing fluid on the PCB's (printed circuit boards). Does the pic blank or flicker?
In either case I would say your TV is sick and that you need to see an Authorized Service Center DR. Always ask for an estimate before any repairs are performed.
Good Luck, big IRISH.
Posted on Aug 16, 2008
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
My wonderful Coolpix recently seems to be letting in too much light when I go to take a picture..worked fine before
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Sep 29, 2015 | Nikon Coolpix S3300
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture...
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Dec 04, 2013 | Cameras
What is the part number of the headlight bulbs for an 05 Ford escape
This is from the osramSylvania web site.
Low beam headlamp
H11
H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
H7
H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Jan 21, 2011 | 2005 Ford Escape
Pandigital pan 70-0 progressively got darker. now you can bearly see picture
Hello. your frame has a dial on the side which makes it brighter or darker. Just turn the dial to adjust it. Regards, Joe
Feb 17, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
I just turned on my new plasma and the top & bottom ~3 inches are brighter than the rest of the picture in the 16:9 ratio. How do I get rid of this problem?
my old television had the same problem, or rather my uncles television. to fully get rid of this, you may need to replace your light drive, but otherwise, we fixed it by changing the angle of the tv so that the darker or lighter side was less of the tv.
Jun 10, 2009 | LG 50PG30 Plasma HDTV
Picture pulses
replace the flote.
any repairman will know wat this is.
part cost is from $56 to $93.
check around
partsstore dot com keeps a good parts stock for tompson or rca.
hope this helps
regards,
daniel.
Jan 13, 2009 | RCA P60921 60" Rear Projection Television
Blinking picture
Do me a favor funstuff send this to my personal email address along with the model number. I get about 3000 emails a day so it's difficult for me to remember what model we are talking about...
Bill
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 02, 2008 | Televison & Video
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
