Question about Hoover Vacuums
I HAVE A HENRY HOOVER AND RECENTLY ONE OF THE SMALL BRASS CONTACTS BROKE OFF THE CONTACTS INSIDE THE CABLE REWIND PART. I ODERED AND RECEIVED A NEW CONTACTS KIT. I WAS WONDERING HOW I REMOVE THE BRASS CONTACT WHICH APPEARS TO SECURED ONTO THE HOLDER BY WHAT LOOKS LIKE A SMALL RIVET TYPE THING HOLDING IT ON. THE NEW KIT HAS 2 SMALL BRASS PIECES, WHAT WOULD THEY BE FOR?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Perhaps if you were to add some detailed photographs it would clarify the problem better than a description!
Posted on Oct 17, 2017
3 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: henry hoover
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=26736&thid=552936
Henry Hoover
Posted by modbod on Apr 28, 2008
Automatic rewind cable not working. Cable will only come out a few feet then jams. Currently using an extension lead. Any advice on how to free cable much appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I am sorry that Henry Hoover is having a problem with his cordwinder and what happens that the cord tends to overlap the other cord inside of the vacuum and what needs to be done is this; #1 take apart the cordwinder and unwrap al the cord all the way out then re-wrap the cord and re-install #2, if that does not work then lubricate the cordwinder but not the cord to have it work more efficiently, and #3 if all else fails replace the cordwinder with a new one. Always when using the cordwinder, always pull out everything until the end to use the cord all the way out to prevent the cord from over lapping and binding up inside the Henry Hoover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
  • 14 Answers
SOURCE: numatic henry making strange spluttering sound
Sounds very poorly. If you have renewed the brushes and contacts it is now more likely to be the motor. If you check, I expect the copper windings or the armature are black and burned. A new motor can be obtained from the manufacturers www.numatic.com or in the UK you might find it cheaper at www.a1cleaningsupplies.co.uk
Posted on Jun 08, 2009
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
How do I make the noise stop?
Seems like the bearing on the side of the roller has gone bad. If there is a dirt gone deep inside, it is hard to clean it. It can also go bad if the roller hits the uneven surface like the transition strip between carpet and tile. It can unbalance the roller causing it to go off its axis and get misaligned.
This is the roller for the Hoover Elite Rewind
http://www.ezvacuum.com/hoover-93002124-brushroll-for-u5509-u5511-u5512-elite-rewind-p-3607.html
May 20, 2013 | Hoover Elite Rewind Bagless Upright...
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
Numatic henry making strange spluttering sound
Mar 25, 2009 | Numatic Henry Bagged Canister Vacuum
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
Henry hoover
Henry Hoover
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Henry Numatic "" Canister Vacuum
Vacuums Logo
96 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
