Need to download driver i think no sound comming out of computer my adapter from my speekers goes into the back of computer when i had a look inside it is attached to a small sort of box that says suyin connector
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
Posted on May 20, 2011
No sound systemax with dell hardrive
Got speakers?
(Got milk? Envision Megan Fox asking)
"no speeker in the desktop box in the right eather."
How are you going to hear sounds with no speakers?
Speaker on the inside of the computer, would have been for hearing BIOS Beep Codes.
The computers way of telling you something is wrong, and an area to look into for it.
Moving on.......
I need the model number of the Systemax desktop computer.
Should be on the back next to the Windows product key, or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | Systemax Computers & Internet
No sound on speekers driver 5.1 sb 0220 required
Creative Labs audio drivers are available from their WEB downloadsite - click on this link and select your model audio card to download : - http://support.creative.com/
Jul 15, 2011 | Creative Labs Sound Blaster Live! 5.1...
I canot hear any sound from my pc (xp)
install your sound device driver go here and clic on lancer la detection
www.ma-config.com
DON'T FORGET TO RATE
Jun 26, 2010 | Microsoft Windows XP Home Edition
Speekers no sound
Sounds to me like the amp needs power. Is it usb powered? or have a wall plug?
Oct 28, 2009 | Boston Acoustics BA735 Computer Speakers
I cannot hear any sound from my computer.i think driver for the sound is not working.the port for the speeker is inbuilt.the motherboard is raffles via motherboard.
To check, click windows start button, point to computer, click manage, then look for device manager. If you see an exclamation or "x" mark on your audio device this means that your audio driver is not properly installed.
Re-install your audio driver.
Jun 03, 2009 | Computers & Internet
Sound problem
my pc have speeker but cannot give sound my speeker is ok. but some body ask me install soun driver where i solve this problem please help me
May 19, 2009 | Biostar 945GZ-SE Micro Socket 775...
Wireless connection
You'll need to download this software for the card and re-install the driver. You can download the 5MB driver here:
http://downloads.linksysbycisco.com/downloads/WPC54GX_0(2),0.zip
Once you get it, open up the folder, and run the setup.exe file inside. This will put the drivers where they need to go. If it still doesn't work after that, you may need to turn your Windows Wireless Zero Config service on. You can do this by right clicking My Computer, go to Manage, go into the Services menu, and locate the Wireless Zero Config service. If it's disabled or not started, start it and set it to start automatically.
May 14, 2009 | Linksys (WPC54GS) 802.11g/b Wireless...
When the power come on it makes a Popping sound
Classic convergence driver failure for this unit. I call it "the thumps." Convergence drivers are two large chips inside (STK392-110), one of which has gone bad, but both need to be replaced. There are also several resistors around the drivers that have also sustained damage and need to be replaced. I recommend a television shop do the work for you because, unless you have good, solid soldering skills, the board can be rendered unusable by excessive heat/prying, etc., and the HD input can be **permanently disabled** by opening the back of the Television without properly preparing it.
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Speekers
hello
okay i think your base is too full.
turn off the base of your speekers and then try to play a song or a sound...
if not go to control panel and then sounds and lower down the base volume bar
Dec 10, 2007 | Audio Players & Recorders
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
