Question about Garden
I just replaced a rear wheel on my Murray Lawn Tractor Model 38633x92a When I start it up and place it in gear, It will not move. It is as if it is not in gear. What do I do?
    Sergeant:
    Champion:
  • 202 Answers
You took off the wheel and a key fell out of the axle-you need to get another one and it goes on the axle and has a corrosponding spot on the rim that "locks" them so when the axle turns-so does the wheel! Good luck.
Posted on May 20, 2011
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray model series 760 lawn tractor speed control. Tractor won't move.
Well the lever is obviously not reaching the motor so fix the lever
Feb 18, 2015 | Murray Garden
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
I need a manual for a Murray self propelled lawn mower Model No. 20905X8C. When I went on the Murray website, I had to have the manual to look up the part numbers. This particular manual is not on-line so...
You need a rear wheel part# 71133MA. A place to look up this model would be at www.precisionope.com. Look up OEM parts section, in may be under Murray or Briggs & Stratton. Briggs bought out Murray out several years ago.
Hope that helps.
Sep 25, 2009 | Garden
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replaced my rear wheel now my lawn mower does not move.
when you removed the wheel be sure you have put the keystock back in the slot cut in the wheel and the axle shaft in each wheel if you had both off
put the wheel on the axle shaft and align the slots and insert the key stock once the slots are aligned with the axle and wheel.
insert by hand or tap lightly with a hammer and insert the keystock far enough to reinstall the axles e-clip
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
