Question about Garden
I seem to have the same problem. I can easily pull the rope on the Cub Cadet but won't start and seems to have to compression. Is this something that I can fix on my own?
    Sergeant:
    Champion:
  • 202 Answers
1st make sure you have spark at the plug by removing it and pulling over the motor, then drain and replace gas and install new plug if you do. The new blend of fuel is only good for a few weeks of shelf life. Ifyou plan on storing a 2 cycle motor use marine stabile in it or it will not start.
Posted on May 20, 2011
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
I can't start my cub cadet snowblower. Pull rope is stuck. How can I fix?
Take the cover off the rope starter and look for broken parts, also are you sure the engine is not frozen up?
Jan 12, 2017 | Cub Cadet Garden
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
What makes the mower hard to pull at start
Don't take my word for the hard pull start , but you probably should have a mechanic dissemble
the pull start assembly. I am only guessing it needs to be cleaned and lubricated.
Jun 11, 2011 | Cub Cadet Garden
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
