Question about Continental Tire North America Continental Traffic ATB Bicycle Tire Wire Bead
What type of adaptor is needed for the tire stem of the traffic tire?
  • 76 Answers
If its not a schraeder valve then you will need a presta valve adapter.
Posted on May 20, 2011
How do I remove a valve stem from riding mower rim?
If your simply replacing it with a new one or installing an inner tube you take a sharp knife and cut back side off. Don't cut completely as you want to catch that piece before it falls inside the tire. Then you simple pull the stem breaking that piece off, catching the back piece as it falls.
If you wanting to put back in a new stem for tubeless use you need a t-shape valve core wrench. After you place the new stem in the hole you thread the tool on and pull the new stem into place.
Jun 22, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No tire or tube on rim. where do I start for trying to put the new tube and tire on?
its somewhat hard to explain in words
check this video out
http://www.youtube.com/watch?v=u7KJK_rl9cU
also most bike stores will probably help you out for free
Nov 09, 2010 | Cycling
2008 kia sportage with damage to tire valve stem, TPMS sensor is okay. Tire installer states valve stem is corroded and tire has slow lwak through the valve stem. how do i get this fixed?
Replace the valve stem or have it replaced. There is a special tool to unscrew the valve stem. Remove the wheel and tire from the car and depress the pin in the stem to release the air in the tire. When you have about 90% of the air out of the tire, insert the tool into the stem an turn counterclockwise to remove. After you install the new valve stem, get a ride to a gas station that offers free air and fill the tire up. As long as the tire is still seated to the lip of the rim (check just for your safety but I very highly doubt it unseated from the rim) and fill the tire to the cold psi rating which is stamped on the sidewall of the tire. If you want to check the tire itself for a slow leak prior to doing the steps above, here is what to do. Get a pan or plastic tub that is sightly wider and longer than the tire and rim. Fill the tub with water and set them it in the water (while it is still filled with air) and slowly roll the tire in place and look for small air bubbles to rise. If you see bubbles, there is a leak.
May 12, 2010 | 1996 Kia Sportage
One tire is not showing a psi-new tires put on this weekend what do I need to do?
Hi
It sounds like the tyre needs a new valve, they also have a very small screw head inside the valve but you need a special tool to tighten them up, again this could be at fault. easy repair.
Apr 19, 2010 | 2009 Nissan Murano
I have a 1999 grand am gt1 im installing new rims and tires will i need to buy new sensors
No you should not have to by new sensor. If you mean the ABS sensor's there attached to the wheel hubs and if you mean the tire pressure monitoring system (TPMS) there are two types. Once is with your ABS system and the other is with the valve stem on the rims, so if the TPMS is on the valve stem, have the tire shop swap them on to the new rims.
Good luck and keep me posted.
Feb 22, 2010 | 1999 Pontiac Grand Am GT
How much air do i need in my tires
the tire industry recommends 32-34 PSI in all 4 tires
Nov 12, 2009 | 1995 Toyota Camry
Tire Leaks at Valve Stem
not just chrysler, there are many wheels from manufactures that have the same type of problems. chances are they will not help you.
Jun 11, 2009 | 2003 Chrysler PT Cruiser
The tires are flat
You need to purchase an adapter which pushes onto the valve (so it doesn't depress the valve stem) and the other end is a standard screw fix to a bicycle pump.
Any good bicycle store stocks them.
The valve you are desrcibing is pretty standard on racing type bicycles.
Good luck and let me know how you get on.
Mar 04, 2009 | Radio Flyer 1800 Big Red Classic Wagon...
Continental Tire North America Continental Traffic ATB Bicycle Tire  Wire Bead Logo
71 people viewed this question
Top Continental Tire North America Cycling Experts
John Egan
John Egan
Are you a Continental Tire North America Cycling Expert? Answer questions, earn points and help others
