Question about Baby Gear
Have an older style XTS boogie 2 pram. Got it second hand and can't remember how to fold the chasi down. please help! I've pulled the red button thing on the right hand hinge but nothing happened. Can't see any other catches that needs releasing.....
  • 419 Answers
Gosh, this is testing my memory! I believe that there is a black lever on the handle bar. This is on the left hand side. Place your hands in the normal pushing position, then slide your hand down and following the natural curve and underneath where the hood sits there should be a lever type thing (can't think of a better way to describe it!). Press this lever down, then release the red button on the right hand side, then push the handle toward the floor, that should do it.
Hope this helps.
Posted on May 21, 2011
Have bought second hand mutsy stroller, no manual and no idea how to fold the chasis down!
First remove the seat or carrycot/car seat if this is on the chassis. Then, stand to the left of the chassis. Push down the button on the handle which lowers the handle bar height with your right hand. With your left hand, take a hold of the black cuff on the side of the chassis (this should be about waist height). In one movement, you need to pull the left hand up, whilst pushing down your right hand, this needs to be done at the same time, and with some force.
When the chassis is lowered toward the floor, this will click shut. To open the chassis, there is a small metal arm on the left hand side of the chassis with a red cover on (this is quite little) you need to lift this button upwards (towards you) and the chassis will open.
I hope this helps.
Nov 13, 2009 | Mutsy 4Rider - Red Stroller
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
To open pushchair i need to turn it upside down ,get on my hands and knees and make a complete fool of myself ,i must be doing something wrong.....please help
The best advise that I can give is the following:
Kneel behind the stroller.
Push in button 1 (the left hand-side) with the heel of your hand, whilst keeping this depressed, push button 2 with the heel of your hand, then whilst your hands are still pushing the buttons in, use your thumbs to push the frame forward - the buggy will then semi fold forward. Push the cross-bar between the handle bars away from you, this will release the elbow joint.
Then, simply push the pram toward the floor, this should fold the pram fine.
NOTE this does take a little practice, but if you stick with it, you will get it.
I hope this helps.
Sep 15, 2009 | Quinny ZAPP Stroller
Folding and unfolding stroller/ how to adjust stroller seat?
if you place your hands on either side of the stroller keeping your hands on the side of the handle at the same time pull uo and that rfolds and unfolds stroller
Sep 11, 2009 | Quinny Freestyle 3 XL Stroller
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
Zooper Boogie User's Manual
There's a safety lock located on the right side of the frame, about 6-8" down from the handle bar. There are also 2 sliding locks, one located on either side of the stroller, on the underside of the frame. One is located just below the safety lock. First pull up on the safety lock, and while keeping the safety lock open, simultaneously slide the other 2 levers up toward you. The stroller will unlock/open and you will be able to fold it.
Dec 24, 2008 | Zooper Boogie Jogger
2nd hand BEBEcar Adventure raider AT+
Hi, I have just bought second hand the exact same pram. You have to push in the red button in the middle of the handle, then turn the handle down towards the floor. By putting a little pressure on it it should now start to fold down. Hope this helps.
I have my own dilemma though. When the carry cot is on as a forward facing pram, does the seat unit come off that you use for the buggy?
Apr 17, 2008 | Bebecar Raider AT Stroller
Help me fold this pram chassis please
Haveyou tried oiling the the chassis. Since they have been in the loft for awhile.
Dec 29, 2007 | Baby Gear
Handle will not fold down any more
We hand handle problems, and no receipt. I just called bugaboo with a serial number and they sent a new chassy.
Nov 25, 2007 | Bugaboo Gecko Stroller
Baby Gear Logo
226 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
