Question about Maytag Refrigerators
My admiral model ltf2112arw refrigerator no longer gets cold enough. The freezer seems to work fine but I can't get the refriderator portion to get cold enough to even cool off pop cans. Do thermostats go bad?
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
peyton32034
  • 410 Answers
SOURCE: Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Posted on Dec 19, 2007
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
SOURCE: trubleshoot refrigerator staying cold enough
These fridgs lose their freon which is likely tke problem in part
Posted on Oct 16, 2008
SOURCE: refrigerator not cooling freezer not cold
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
Posted on Sep 10, 2010
I have an Admiral LTF2112ARW refrigerator. The refrigerator is working but the freezer won't stay cold even though the thermostat is on the coldest setting. Any suggestions about what is wrong?
ITS NOT A GOOD IDEA TO USE THE COLDEST SETTING CUZ WHAT U WILL GET IS EXACTLY THE OPPOSITE A MORE WARM SETTING. A HIGH SETTING CAUSES THE COMPRESSOR TO OVER WORK IT SELF CREATING TO MUCH COLD IN ONE SECTION TO THE NEGLECT OF THE OTHER SECTION. UR PROBLEM IS NORMALLY THE OTHER WAY AROUND TO MUCH FREEZER AND NOT COLD IN FRIDGE.? BUT i WOULD CHECK THE THERMISTORS IN THE FREEZER. AND ALSO TRY ADJUSTING UR SETTINGS TO MED AND CHECK UR AIR FLOW CONTROL VENT AKA COLD CONTROL THERMOSTAT.
Feb 23, 2015 | Admiral Refrigerators
My Admiral mullion is hot
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
Nov 20, 2013 | Admiral Refrigerators
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
My fridiaire refrigerator and freezer model # frt21lr7ab6 the freezer works fine but refriderator will not get cold.
check if you see any ice or frost on the back wall of the freezer that might block the air circelation to the fridge
Sep 02, 2011 | Frigidaire Refrigerators
My refriderator freezer not working and the bottom crispers on the fridge side are freezing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How is the freezer doing. If you have a lot of ice collecting in the freezer the door gasket is probably bad causing the compressor to run overtime which will probably cause the refrigerator portion to cool as well.
You might check the freezer and if very cold set it a bit warmer. I do not know what you have but these may save you some $$$. While you are at it check the freezer, refrigerator, condenser and condenser fans.
Good Luck,
Gilshultz
Dec 01, 2009 | Admiral Refrigerators
Maytag SidebySide model MZD2766GES Fridge portion not working...
yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Aug 05, 2008 | Maytag MZD2766GES Side by Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
472 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
