Question about Lexmark Wheelwriter 1000 Typewriter
How do I clear the automatic codes? WHen I start up computer and begin to type it always types codes. I have to turn off again or type first on blank paper for my typing to begin.
  • Lexmark Master
  • 3,594 Answers
Most likely your keyboard is going bad. You can try my tip under WW1000 or contact Geo Beters Co. @ 800-392-8085 for a KB rebuild. Tell them O'Reilly sent you.
DickyO
Posted on May 20, 2011
  • swatt33 May 20, 2011
    thank you for your quick reply. I will check it out
E000602-0003
Problem with hard disc
Aug 08, 2014 | Canon irc5185i
How do you make the computer relearn the system?
To reset the computer, disconnect the negative battery cable and let it sit for about 15 minutes. Most all codes will clear. Connecting the battery cable again and the computer will begin re-learning the system automatically. I've heard that some hard-set codes may stay in the system and need cleared using a code scanner but, I've not actually come across this before as disconnecting the battery cable has always worked for me.
Jun 21, 2014 | 1999 Chevrolet Tahoe
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Automatic dies and starts again anywhere from 2-30 minutes later.
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 06, 2012 | 2001 Kia Rio
User mode window (for adjusting the contrast, brightness etc) appears again again automatically.
First off... I would Re-Start your computer...OR...Shut down manually... to see if this fixes your problem. It's possible your computer didn't accept the changed setting? But...what you are experiencing is a Corrupt File, which will need to be removed!
Not sure exactly what you did? Where you trying to adjust the contrast, brightness, etc,.?
If you went through your Desktop to adjust these settings, always make sure you select APPLY and OK..
If you went through your System to Change your Resloution, you may have a Conflict with your chipset or even Malfunctioned it?
If re-starting your computer didn't fix your problem, than shut your computer down again!
Upon,..Re-booting...This time hold the Control Key down, so you can get into SAFE MODE!
I would then do a SYSTEM RESTORE under (SAFE MODE) and Restore your computer back to an earlier period that your computer was working correctly! Even, if you cleared the problem on the first step provided! Just type in the search box in your Control Panel System Restore! Or you can type in at the START Button...System Restore!
Also, while in SAFE Mode...go to your Device Drivers in your Device Manager and check for any setting that have a yellow symbol next to them...Click on each one and Update the Drivers!
Always, make sure...you Re-Start your computer after doing any changes...!
If you need further assistance, please don't hesistate to reply back to me! I'll be happy to help you!
Kind Regards!
Martie
Sep 10, 2011 | Dell E773C 17" CRT Monitor
What is the code to enter service mode to clear error codes and reset the drum status...receiving error code 100 after changing toner cartridge and will not print.
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Canon imageRUNNER 2010F All-In-One Printer
Starting problem, sometimes automatically restarts or shutdown
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 16, 2010 | Dell OptiPlex GX280 PC Desktop
My windows can't check for updates (windows vista home premium). it's showing error code 80244019
Press Win+R, type 'services.msc' and press Enter. Respond to the UAC prompt. Check that Background Intelligent Transfer Service is started and its startup type is 'Automatic.' (It can also be Automatic (Delayed Start).) If it is not started, right-click on it and select Start. Scroll down to Windows Update to make sure that it is started and it startup type is 'Automatic' or 'Automatic (Delayed Start).' If it is not started, right-click on it and select Start. If you had to start either service, try to run Windows Update again by clicking on Start -> All Programs -> Windows Update.
Apr 14, 2009 | Microsoft Windows? Vista Home Premium...
Office 2004 for mac automatically starts each line with a CAPITAL
To turn off automatic spelling corrections and all automatic formatting:
  1. On the 'Tools' menu, click 'AutoCorrect'
  2. Clear the 'Automatically correct spelling and formatting as you type' check box.
Tip: To specify options for checking spelling, on the 'Word' menu, click 'Preferences', and then under 'Authoring and Proofing Tools', click 'Spelling and Grammar'.
To turn off automatic capitalization and text corrections:
  2. Click the 'AutoCorrect' tab, and then clear the check boxes for the options that you want to turn off.
Tip: To turn off automatic spelling corrections as you type, clear the 'Replace text as you type' check box.
Jan 04, 2009 | Microsoft Office 2004 for Mac
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Lexmark Wheelwriter 1000 Typewriter Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
