Question about Acer Aspire One A150-1006 Notebook
Doesn't matter what key that I press on my keyboard...will only come up with numbers in succession - 0123456 etc and the num lock is NOT on
    Sergeant:
  • 187 Answers
CHANGE THE NUM LOCK BY PRESSING THE FN KEY +NUM LOCK KEY.PLS REPLY OR COMMENT. THANKS
Posted on May 20, 2011
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Acer Aspire 5002WLMi Keyboard problem. I somehow did something to my keyboard set up so it is using the secondary options. For example, when I type the letter K, it comes up a 2. L comes up as 3 etc. I...
Try holding the Fn key, usually blue, while pressing the "num lock" key, which is usually above the 7. This should release the number pad function of the keyboard.
Let me know if this doesn't fix the issue!
John Vickers
Sep 18, 2011 | Acer Aspire 5002WLMi Notebook
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
Have a new wireless HP keyboard for all in one omni 100, keys do not correspond on screen with keyboard, have tried adding different language keyboards in regions to no avail, what am I doing wrong_+(* ...
It's possible that you have hit the Num Lock key while you had another key pressed. Try the following combinations, one at a time, to see if any of them work. Be sure to test each one before moving on to the next one.
CTRL and NUM LK
Shift and NUM LK
ALT and NUM LK
A lot of times characters will swap places if one of these combinations has been pressed, and pressing the combination again should switch it back. Let me know how it goes! If this doesn't work, we'll try something else.
Aug 26, 2011 | Compaq Keyboard
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
My wipro laptop keyboard keys are mixed up.if i press j 1 is displayed.its very difficult to type thrugh gon screen keyboard.plz help me.
You've got num lock on. To verify that, look for a Num Lock LED that is lit, should be near the screen on the keyboard side of the laptop. Often marked [1] or NumLock.
Simple fix, find the num lock key (or combination) and press it. If that doesn't work and the numlock LED is lit no matter what you press then you have a screwed up keyboard.
Your BIOS might be set to do this when the PC turns on. To fix that, look in BIOS setup for an option called "Boot Up NumLock" and turn it off.
Aug 13, 2010 | Computers & Internet
Number pad on iMac keyboard inactive
Press "clear" on the numbers pad, then the numbers will type.
Jul 28, 2008 | Apple Power Mac G5 Desktop
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
Acer Aspire One A150-1006 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
