I am trying to wall mount a hitachi hit19wdvbdvd and cant see any visible screws in the circular stand I need to remove. I have tried to release the back panel via 6 screws but the back cover will still not come off any advice please.
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SOURCE: Can not remove the rest of the TV stand
I am the owner of the Panasonic TX-32LZD60, and finally managed to solve the problem myself.
So for anyone else out there with a similiar problem, you need first remove the two screws at the back of the TV which are low down. Take of the small plastic casing. Underneath you will see two rows of a total of 8 screws, which go through a black metal plate. Remove these and the stand will slide out. Not bad for a girl!!
Posted on Dec 20, 2008
  • 27 Answers
SOURCE: Lost Screws for stand for Insignia IS-LCDTV32 32
they are couse scews your best bet is go to lowes or home depot and get a few of each 1/4 inch screws to see which one fits they only cost about .03 each
please rate my answer it is much apreceated
Posted on Feb 13, 2009
  • 34 Answers
SOURCE: taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Posted on Apr 08, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
Hi, My dvd has got stuck in my hitachi hit19wdvbdvd player the eject button won't work.
unfortunately, if the drive is stuck, the only way to retrieve your disk would be to take the unit apart. Be careful though as this will void any warrenty. Make sure the set is switched off and unplugged before attempting this, be careful as even when switched off, some tvs can still hold a lot of voltage.
May 05, 2011 | Hitachi Televison & Video
I have taken the stand off my samsung tv to wall mount it but there is a circular part still on the bottom which is below tv and it doesnt look right? is this part removable?
Yes, but you have to unscrew it, then pull it out.
At the back of the TV - bottom centre - there will be a black plastic semi-circular protrusion to which the circular part you refer to is connected. There are 2 screws just above this and 1 each side (4 in total). Remove these screws and both the plastic protrusion and the cylinder which was attached to the stand will pull out. I think it pulls away backwards, rather than downwards.
You can then attach the wall bracket and Robert is your father's brother . . .
Oct 17, 2010 | Televison & Video
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Plasma stand removal
take the screws out that are holding it in!
Apr 12, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
