Can i use the cold feed on the hot feed for my washing machine?
  • 157 Answers
No need to rinse in cold other colour will run and shrink.
Posted on May 20, 2011
barkencoa
  • 3463 Answers
SOURCE: WHIRLPOOL AWO/D 5726 - cold water feed only?
Most washers now made in the u/k, are cold fill only, but if the new washer is hot and cold fill, and you only have a cold supply, then it will tell you in the installation guide how to connect it to use it from cold only.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
  • 13 Answers
SOURCE: GW52F Fisher and Paykel Washing Machine
you should check new washing machine..i know a effective site..
http://www.washingmachineadvisor.com/
Posted on Feb 02, 2010
SOURCE: washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
Posted on Apr 28, 2010
  • 27 Answers
SOURCE: can the washing machine run on cold water feed
you can use a cold feed on washes below 50 degrees
if you need to connect a feed to the hot water inlet on the machine you can buy a y shaped connector to join both pipes together from the machine and then connect the one remaining connection to the water supply valve
Posted on Dec 04, 2010
Can i connect to a cold water feed, i do not have a hot feed
I am assuming you can select water temperature on your machine. Simply hook up your pipe to the cold water feed on the machine, and leave the hot water feed alone. Always select cold water on the machine before beginning a load. If it makes you feel better, cap off the hot water inlet on the washing machine.
Nov 27, 2012 | Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
I have 4 year old Hotpoint washing machine with hot feed and cold feed. have moved to new house with only cold feed. Will it still work? Do I need to plug the blank hot feed on back of machine?
It Will work ...However you will need a Y piece connector both hot and cold hoses connect to this costs around £2.. ..A cheap fix..
Feb 08, 2010 | Washing Machines
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Please rate my solution.
Thankyou.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
