Question about Motorola MC75
Downloaded censitrac program it took over the whole pda and cant get two other programs or menu
Want to program my pool but my aqua link 8265 PDA does not show the "PROGRAM" menu, as per the instructions..
your aqualink has a one touch chip in it you have to program with the hard wired controller if you dont have one you need to upgrade the chip to a PDA chip to program with the hand held
Sep 18, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Cant get google maps to work
Hello, Altrough I am not experienced with this particular model you may try the following method. First back up all your data on the internal memory of your device.This will allow you to restore contacts, programs or other data after you perform a master reset. Save the backup file to a memory card or another external storage device. Then hard reset the pda, to restore it to the factory settings. After this is done, install the program (google maps) after the pda's initial setup (wich occurs after the hard reset). Now check to see if the program works. If not, the logical assumtion would be that the program wasn't clearly designed for this pda model. Please notice that altrough all these devices run Palm OS, the actual operating system is different in order to fit each model's hardware specification. So it isn't like windows xp for example, wich can run on any computer, regardless of it's manufacturer or hardware components. If the program fails to work after all of this, you can either wait to see if google comes up with a patch to the program or a newer version that includes your pda in the suported devices list. Meanwhile you should use the backup you just made to restore the device to it's previus state. Please come back with a reply if this fails to work. Good luck.
May 27, 2007 | Palm Treo 680 Smartphone
Touch portal program
CLICK HERE for a download site. Click no on the popup box and the download box will come up.
Jul 23, 2013 | Computers & Internet
My sony psp said the data is corrupted when i downloaded the psp pda
if you downloaded the pda onto the psp then that is why.
psp's do not read the format pda however there are programes you
can get for your pc/laptop that can, so put it on your computer.
Mar 19, 2011 | Sony PlayStation Portable (PSP) Console
Not able to download PDA software @ www.angelbroking.com its use for trading ... while downloading this software errore is showing.
if downloading via pc,use a download manager to get it (jdownloader is a great program for that) just copy the link,let the program get it and click continue with all to get the program error free.its a matter of transferring it then to your pda
Mar 08, 2011 | Computers & Internet
I have a new PDA a palm TX I purchased on ebay and
No, you can install it without removing the other, and yes you can install more programs.
Jan 10, 2010 | Palm TX Handheld
P3400 audio manager dosen't play any mp3 and i can't put any mp3 as aring tone
alternately u can do this
if ur phone is HTC P3450 ELF or HTC3452 ELFIN there are 2 versions of this device then go to start >Programs>fileExplorer>select music file u want to set as ringtone, and then long tap on the file for like 4 sec a menu will appear u can select set as ringtone and ur file will be set it is the std procedure for it
and about that HTC audio manager u can check for updated ROM from www.htc.com >ur region >support and then check if new ROM is availble it i will address ur issues of audio manager
but if u really want a new look for ur PDA and want to make it like touch HD then my friend i will suggest this but at ur own risk but the results are really worth it
see this update to CUSTOM ROM for ur pda and u will get more free memory for programs and storage i know it is a big rpoblem in this pda and u will get new look like touch hd
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
and then Lite version for ELF from here
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA for my response i have lots of tweaks for PDA's
Mar 06, 2009 | HTC Touch P3450 Smartphone
Imate jamin mobile
hi thanks for using fixya!!
You may install programs to your Imate by using ActiveSync, just install first your activesync to you computer and then after the successull installation of the Activesync, connect your Imate to your pc using usb cable, then click activesync from your pc then it will automatically prompt you for your preferred activesync settings.
Then on installing programs, if you have the program in you pc just click the program to run and then it will automatically install it to your pc and PDA, but if you want it to install directly to your PDA, you should copy the program using activesync to your PDA, just save the prorgam file to the internal memory or to the sd memory and then from your PDA you may install it smooth and easy.
If you do not the activesync you may download Here
If you need further, let me know!
Please rate my simple solution positively! thanks!
Jan 31, 2009 | i-mate JAMin Smartphone
How to occupy the whole screen when watching a movie
What you need to download is a program called PocketDivxEncoder.
Just run the program and select either the Smartphone or the PDA icon at the first prompt, then browse to the movie file on your computer and then allow the program to re-encode to fit your phone screen. Since your screen is 320x240, try either of the smartphone or PDA setting. You'll also be able to tweak the settings manually if it's not exactly what you wanted.
Have fun and once you get it working.. don't forget the popcorn. ;)
Mar 13, 2008 | Samsung Blackjack SGH-I607 Smartphone
Some programs not running
Take a look at this similar post - http://www.fixya.com/problems-solutions/t115221,p477250/HP-iPAQ-hx4700-Pocket-PC.aspx Let us know if you resolved your problem Good luck
Jun 27, 2006 | HP iPAQ HX4700 Pocket PC
Motorola MC75 Logo
118 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
